New from SMS Revell Painta Micro Applicators 100 Pack 39619
Revell Painta Micro Applicators – 100 Pack​
Revell Painta Micro Applicators (39619) are precision application tools designed for detailed scale modelling work. Supplied in a pack of 100, the set includes four different tip sizes, allowing modellers to choose an applicator suited to the size and accessibility of the area being worked on.
Unlike conventional brushes, these micro applicators are designed to absorb a controlled amount of material and release it precisely where required. Their finely formed tips help reduce unwanted drips, contamination and material waste, particularly when working on small components and detailed areas of a model.
Four Applicator Sizes for Precision Work​
The pack contains 25 applicators in each of four sizes, ranging from 2.5mm down to a slender 1.2mm tip. This selection provides flexibility when moving between different types of detailed work.
The larger applicators are useful when a broader application area is required, while the smaller tips allow more precise placement of material. The slender 1.2mm applicators are particularly suited to working in restricted spaces and around fine model details.
Pack Contents – 100 Micro Applicators​
Each pack contains:
  • 25 x 2.5mm micro applicators
  • 25 x 2.0mm micro applicators
  • 25 x 1.5mm micro applicators
  • 25 x 1.2mm slender micro applicators
With 25 applicators of each size, the set provides a practical supply for repeated modelling tasks. The four tip dimensions also make it easier to select an appropriate applicator without relying on a single size for every job.
Controlled Application with Less Waste​
The tips are designed to absorb material without dripping and release it in a controlled manner. This helps keep application focused on the intended area rather than spreading material across surrounding details.
For scale modellers, this control is especially useful when working on intricate assemblies or areas that are difficult to reach with larger tools. The fine tips let you place material accurately while minimising unnecessary waste.
The applicators also help reduce contamination during detailed work by supporting controlled material transfer. This makes them a useful addition to a modelling workbench where precision and careful handling are important.
Suitable for Detailed Scale Modelling​
Revell Painta Micro Applicators are intended for tasks requiring accurate placement of small amounts of material. Their range of tip sizes allows modellers to work on different areas of a project, from more accessible surfaces to narrow spaces and fine details.
Part of Revell’s micro brush and applicator range, this 100-piece set combines four tip sizes with controlled absorption and release. The 1.2mm slender applicators offer the smallest tip option, while the 1.5mm, 2.0mm, and 2.5mm sizes provide options for larger application areas.
The post Revell Painta Micro Applicators 100 Pack 39619 appeared first on Scale Model Shop.
