Hi all.
The “Richard’s Layout.” is my new train layout project. (Richard is the name of my father)
Maybe, some of you know I have an actually current project, is an HO outdoor layout, which I’m building with my father. Anyway, seems this one is a long, long one...
My father is “OK”, but during this month (December), he wills entry to the operating theatre. My intention is finish it when he arrives at home...and have a good recovery playing with it!!
As I’m looking for a “fast build” I choices a different and smaller scale, the N one (1:160) and the layout is a pre-built item by NOCH.
This is the Digitales Starter Set by Fleischmann (Item 931486).
The set contents the Fleischmann MultiMaus (is a “simple” copy of the Central Station by Marklin...), three good wagons and one diesel locomotive class 212 with DCC decoder. The track is built using the System Fleischmann Piccolo.
The base of the layout is this “kit” by NOCH (Item 83870 “Staufen”). The base comes without any track and buildings. Only contents the necessary bridges. After a fast look, is a simple base....but you can add all kind of complements and repaint the bridges, stone walls and streets for a good final result
Well....I will invert, every day, many hours as I can on this project! Is important that the layout should be finished at his back
Anyway will try to post the step by step guys!
Thanks for looking
Polux
Thanks for looking
Polux
