Rick's 1-87 Scale Luftwaffe Airfield Fuel Tanker
'ere we go again, making better progress on this than I expected. Got the wheel and levers in place, located and installed a grab rail as well as widening the running boards and installing safety tread. Scrounged around in the junk box and came up with a soft top that nearly fit! still some minor mods on it but sat on for a look see. P1012616.JPGP1012617.JPG
Been plugging along on this....starting to finally morph into what I had imagined it should look like. I found myself so inspired by Scotties efforts on the "Pink Panther" Land Rover that I just had to try and scratch build a 1-87 scale Tail pipe clamp........if you squint real hard you might be able to see it in this first photo. Nothing is glued into its final position. Once I have completely fabricated and fit it all together then it will be paint time!P1012619.JPGP1012620.JPGP1012621.JPGP1012622.JPG
Don’t know how I missed the start Rick but I’m in seated by John. Nice scratch on the update
Thanks Lee, getting close....just need to install the wipers and hitch, fab up some windshield glass and it will be ready to go to the paint shop. Glad you made it to the party! ;)
Right Scottie, but when I get in the "groove" ,it's just about how much fiddly stuff I want to do....once painted, half this stuff becomes invisible! ;)
Thanks Mick, should be going on with the paint in the next day or so.....got the last bits on this earlier today so when the glue sets the paint will happen.:thumb2:
We'll see Lee, right now I'm thinking about my next build for the diorama. It will be a Phanomen Granit 25H ambulance. Maybe I'll cook up a batch when I start that build thread. :thumb2:
Well here is the last update before paint flies......wipers installed, added rear license plate with a tail light stem, added the tow hitch, drilled out the headlight buckets for lenses and as a final touch, I bent the front axle to give the appearance of the wheels turned slightly to the left.....just to add interest on the diorama........oops, just noticed I need to install the driver's side mirror.P1012624.JPGP1012625.JPGP1012626.JPG
