As most folk are aware, rotors are not rigid. When the rotors are not spinning they droop! When rotating they are either straight when power is not applied. However when power is applied, Collective lever raised for lift, the blades 'cone', ie they are bending upwards.
My question to the forum is; How do you achieve the droop or upwards bend if in flight on your models. The rigid plastic has to be bent to achieve this. What I don't want to do is turn the electric paint stripper on them and have five piles of molten plastic!!!! :worried: My initial thought was soak in hot water and lightly bend until I get the correct amount of droop!
Any suggestions gratefully received.:thumb2:
