Russet...
I'm reading the instructions of a spitfire MK IXe, my next build, and I have to paint the pilot "chair" with this colour... I don't have it in my stage... Someone knows if it's more similar to red or like red/brown?
Thanks
Polux
Red brown will be fine. I use Vallejo mahogany with a drop of red.
you want to try for a chestnut colour (de color castaño)
The 'red seats where made from a plastic material so no metal chip marks either!
Polux, most native english speakers would be unsure of exactly what colour "russet" is. It's an old word for a brown/red colour, often used to describe autumn colours such as the leaves on the trees before they fall.
You won't go far wrong with Edgar's photo.
Oi! you saying I'm old LOL
You can't be that old! According to the online etymology dictionary the word has origins in old French and was originally a reddish-brown cloth. It has been used as an adjective since the 14th century. It was applied to a type of apple in the 1620s and a pear in the 1720s, but I doubt you remember that either :)
The application to a red-brown colour has remained consistent for about 700 years which is good going for any word!
Nah not that old but old enough to know what it means and use it ;)
Thank you 'old' guys... ;)
Steve# in a few days will open the thread, and will try to do a complet one! Similar your fantastic ones!!
I'm happy, I know, there is very friendly members if you need help ;)
Thanks!
Polux
Just to add that the early Spits had a metal seat in green, from May 1940 they had the fibre/bakelite ( actually, it is SRBP-synthetic resin bonded paper) russet coloured one. There was a issue with the bonded strength of the seat prior to that date. This seat was moulded so technically it isn't Bakelite as the granular plastic takes a controlled heat and immense pressure to form and cure properly hence the use of Resin Bonding. The same seats were fitted in many aircraft, Hurricanes, Vampires etc.
Si:)
