Thanks Steve, it's still WIP, on shift work at the moment.
Don't bin it John. What did you use for the mud/water effect on the front ?\ said:Well this one is heading for the bits bin, its a case of brain exceeding skill level.View attachment 97311 View attachment 97312 View attachment 97313 View attachment 97314 View attachment 97315
Well bench all cleared ready for next project, anyone know what the Mini art figures are like, thinking of getting the Samuri.
Thanks Ian but I think its to far gone, I used clear sealant on all of it so it will be a bitch to remove it & start over, I do not intend to throw it away just use the parts for other things so it will not be a total loss.\ said:Don't bin it John. What did you use for the mud/water effect on the front ?Also can you pull the FSCV back a little ? Just so the front is poking out over the edge.
If you can,use clear sealant to go in front of the tank ( I will use the word tank just for ease ) to make a bow wave to cover the front and go over the sides to form one solid wall of water. If you go and have a look at the Hummer sig builds there's one I did to show you what I mean so you should be able to recover this great build rather than throw it away.
Well Monica I think I will go for it changes is as good as a lest.\ said:I agree with Ian,on what to do Gavin,1st off dont bin it,you can save it ,it dose not real look that bad,if its some were in the Ukraine,has that very think,
sticky mud that dose bog down most things,so just replace it,as Ian said and will be fine,
I have looked at that Samuri.,figure a few times along with some others,and just end up looking looking,
is as far as i have gotten,![]()
"Urban Pacification" ????? .............. Is that Russian for "I'm just taking over your country PASSIVELY Comrade" ??????\ said:Well its supposed to be an urban pacification weapon, so a street scene?
