SAA T-72A "Labna" ca 2014
Steven
Fingers crossed competitions are a go in Demark in the Fall, Let’s face it I am not going to finish “BMP in Aleppo” with the tunnels and buildings and …stuff to accompany the “SNIPER! – outskirts of Aleppo” – dio aka “ZSU 23-2 Technical - a side project” which is 99,5% done this year (yes I am aware of the irony that a side project finish first…).
So, I thought a smaller more manageable project would be the way forward.
I got Trumpeteer’s T-72A ,mod 1985 which I thought would make a Good civil war – era Syrian Arab Army M1 “Labna”, (Arab for brick) i.e. a very early field modification, ca 2014, featuring (in various configurations) a cage made from rebar welded to the turret and (initially) filled with bricks – hence the name -as a somewhat desperate means to do diy protection against ATGM and RPGs. The vehicles vere at this point fitted with type 1 ERA blocks and some sources claim that the cage set- up was to offer protection in places where these vere lost or damaged- I have been unble to confirm this.
Later somewhat standardized as the the T-72 Mahmiah (shield)with more elaborate designs, the design has been covered by modelers in publications such as Bear In the Sand- Russian Amor in Syria and Libya and Tanker Magazine
I will be drawing inspiration from these as well as my own research, also drawing from details in internet publications such as
https://southfront.org/armoured-beasts-diy-style-modifications-of-syrian-army-battle-tanks/
(Conceptual) Scene:
During a lull in the fighting two crew members snap a quick group selfie during a break in re-arming.
Figures from Paracel, accessories (125mm crates and shells) from Miniarm, various bits and bobs.
Although an urban scene, as little in the way of buildings as I can get away with….
I am going to thrash the Hell out the T-72 as ref photos show great wear on the vehicles . In 2014 the Regime was on the retreat with very little in the way of possibilities of properly repairing their ever dwindling supply of T-72s
close - up of the bricks (other than the vehicle above)
Most Likely same vehicle as the one from the screenshot - different source- DIY side panels filled with rubble is a feature on BMP2s of the Republican Gurad in the same period as well and my BMP in Aleppo - dio will feature this. still on the fence I will include them on the T-72 but it is a great example of field mods
Some PE for the model:
side skirts and ERA - blocks - ERA - panels are also torn, bended hanging from brackets and I op PE will help doing this
As I am not keen on doing the sand -and- thin -back - of -the -plastic- heat - to -malable - thing I am also going to get some PE fenders form Voyager which I am going to bend and generally maltreat as reference pics shof these really battered or missing altogether
and a metal version of the 125mm gun barrel from Aber
I am not going to go into much detail about the kit itself as build reviews etc. Are plenty on trumpeteers kits but focus on the Construction of the cage, side protection and weathering
This will be my first attempt at comprehensive use of the oil paint rendering so let's see....
I got bored doing roadwheels so I turned my attention to the rebar cage.
I made a test - build to see if , following Martin Kovacs excellent example in Bear In the Sand.....I could make twisted 0-2mm wire look convincingly like rebar - I am pleased with results
Test build on my old Tamiya T- 55:
Thanks Jim, I thought so too.
Now, I guess there is no excuse not to get on with those roadwheels....
Even with diysideskirts covering many there are still quite a few ERA blocks on the model
I bought ET models PE blocks to get crisp details but the kit's are actually quite good and what will be gained in the PE will result in a very labor intensive process
Et on the left and kit's on the right
Cheers mates
Fenders seem to take a real beating in the urban theatre of operation.In a lot of the ref vids and pics show them missing altogether I was planning to use the Voyager t- 62 PE fenders and bash the he.. out of them but the dont really fit the t-72 - aleast not wothout me gping through a lot of tinkering. I managed to get some decent results out of the kit's but i must say nothing beat PE in replicating damage to thin sheet metal
Thanks Gents
Working on the turret
Storyline is that two members of the crew are taking break from rearming during a lul in the fighting
In this context it would make sense that both hatches were open as Ammo is brought in through these (also this being Syria it is bleeding hot)
So as interior will be visible to some degree I have to do bit of scratching as the kit gives you the commander's and gunner's sights Only.
Once in position the seats will partly limit visibility (here is hoping...) but there's still some parts to add some interest as some are positioned close to the opening
