Saving Private Kitty
rtfoe
Shah Alam, Malaysia
Hi Guys, rather than rehashing an old diorama for MALCOM, I decided to try for a new one. The concept was thought off a year ago but didn't have the time to actually make it so I did the Mission Complete vignette instead. The reason was I had to scratch at least three figures and construct the base with a huge amount of resin water in 70% of the base. There will be five new elements that I will be introducing that I have not done before so lots of experimenting will done as we go along. Palms already sweating as I type. I think I may have opened Pandora's box for me.
Below I have drawn up a plan and the juxtaposition of the little wharf and step makes the measurements challenging... the base of the water level will extend down another 5cm deep as I had cropped that out accidentally.
I also made the three armatures with wire and spue...I would have to shorten the hip sprue.
To help with the measurements I will be needing to cut a block of polystyrene for the back wall. Better to see things in 3D as plan my drawings was getting confusing.
That's as far as I've done. Hope to do more this weekend.
Wabble
Great, got a few of you guys interested.
I spent time yesterday to do the base from normal styrofoam and sheets of the more dense version which will be carved with a stone relief. Note that the height of the wharf includes the water depth.
With this done it will be easier to build up the steps, stilts and platform.
Wabble
Sitting comfortably for another masterpiece. Great interest in watching those figures come together. Should be no challenge for the man who can make a dozen or so monkeys. 😁
Seat front and centre for this one my friend. Great to see this materialise right from the humble beginnings of an idea and a drawing. Good luck
Not, 'Saving Seaman Kitty?'
Wouldn't b e the same joke then, I guess
Looks interesting Richard
Thanks guys, this will be a challenge again for me...everything from the concept, figure scratching, water, action and depth of field. Instead of one figure now I have three to look right and two as fillers... a far cry from monkeys. What goes in the water is another headache. For now I'm tackling the stairs and platform... so much calculation and measurements.
Wabble
Wabble, good to see you building again, my chair is pulled up waiting for the magic to happen.
Hi Paul, good to have you with the west of the pack. Lost the wabbit some time ago, hope something good gets pulled out fwom the hat... abwacadabwa...
Wabble
With scratch built figures and resin water it sounds like an interesting project Richard.
It’s good to challenge yourself and learn new skills….. I’m confident you can pull it off 👍
Thank you Si for the vote of confidence...gotta challenge the grey matter while it's still working.
Wabble
Cutting balsa for the stairs and platform reminds me of wooden blocks we put together as toddlers. The measuring and calculations are tiring and had to stop occasionally to begin afresh.
And here is where I have done so far today... I put a figure in for size comparison.
Wabble
Hi Guys, I've completed the woodwork jigsaw puzzle and will proceed with detailing the stonework, riverbed and railings. Meanwhile I will position the cat on the floating oil drum to help with manipulating the armeture poses. Lets see if I can scavenge some parts so I don't have to sculpt everything from scratch.
The entire structure is detachable for painting.
Wabble
Wabble
sorry Richard, I'm a bit late to this party, but what a superb start!
It may be too late, but you will find the putty sticks better to the wire parts of the armature if you use two strands of thinner wire twisted together, rather than a single smooth strand.
Watching from now on with interest!
Neil
Neil
No worries Neil, I haven't posted on PF yet. Here it's done in real time. I know about the two ply wire style for armatures and I'm not using paper clip wire as that is chrome plated and too smooth. The wire that I'm using is slightly rough and I apply putty in two stages...being fickle I might just change the pose midway through.
Very nice Richard, the structure looks fantastic
Thanks Joe, lots of trial and error went into the structure even after following plan measurements. Just look at the debris from the exercise...
Did it with basic tools. I love working with balsa but it can be delicate.
Wabble
All looking good. Must have taken a lot of head scratching to sort all the measurements and angles.
