Things that cost nothing for modelling.
Scrimpers are constantly on the look out for interesting materials to use that cost very little,or better still are by-products of other things that have extra life in other directions.
Here is one that I have been using now for some time,most modellers use the heatshrink iron on film at some time or another,the plastic backing film makes splendid anti stick material for lining your modelling board,place balsa strips etc to build the models structure pinning to the building board,this saves the plan from damage and also the structure of the model can be easily lifted from the board.
he inner card tubes that carry the film make useful storage for things like balsa strip,just tape a piece of circular card to the base of the tube,you can either store the tubes flat if space permits or in a vertical position against a wall,either way they make excellent storage for strip wood,tubing etc.
The centres of carpets are also made from larger card tube which make good document/plan holders,a trip to your local carpet shop should bring results as the just throw them away.
Here is another unusual source for large diameter plastic tube which has similar uses,have you ever seen those machines in farmers fields operated by gangs of specialists who wrap up the farmers supply of hay ? the black cling film type material,comes on these large sturdy plastic tubes which are just thrown away usually cluttering up the fields ! ask the farmer first and if you are lucky you will have won some first class material,the material is not unlike that plastic tube used for laying services under roads etc.
Always be vigilant and on the look out,you really never know what you will find that has been junked,people are so wasteful,but as a true scrimper that item will find a good use.
