L
Labouring: The action of a vessel slowly pitching and rolling in bad weather and making little headway on course.
Lashings: All wires, ropes and chains used to secure cargo’s. Nothing to do with gravy.
Leading Block: A type of rope block used to guide and change direction of a rope usually into a Capstan.
League: Nautical measure (As in 20,000 of them!), which equals 1/20th a degree of latitude or three miles.
Lee: The sheltered side of an object which can refer to either a vessel, building or a land mass.
Leeward: On the sheltered side of a vessel.
Length Between Perpendiculars, LBP: The distance along the Summer Load Line between the forward and aft perpendiculars. The forward one is at the point where the stem cuts the waterline and the aft one is where the aft side of the rudder post or rudder stock cuts the same. Often referred to as a ships length.
Length Overall, LOA: The total length of the vessel including any extremities. There can be a significant difference in LBP and LOA on sailing vessels.
Light Displacement: The weight of the unladen vessel, measured in tonnes. The difference between the Loaded Displacement and the Light Displacement is the Deadweight.
Lightening Hole: A hole cut into any form of plate that is designed to reduce weight without sacrificing strength.
Lighter: A flat bottomed, unpowered craft for the transport of goods and cargo to and from a vessel.
Lignum Vitae: One of the very few woods that is actually denser than water. This wood was traditionally used as a stern tube and stern frame bearing material in old water lubricated bearings. This was superseded by the advent of oil filled stern tubes with stern seals but, strangely enough, the circle has turned and vessels are now using a plastic bearing material and returning to water cooled and lubricated bearings.
Load Line: A number of lines painted on the side of the vessel at the midship section which indicate the minimum allowed freeboard in a number of conditions and world wide locations. Also known as the Plimsol line and incorporates lines for the following:
Summer Load Line
Winter Load Line
Winter North Atlantic Load Line
Fresh Water Load Line
Tropical Fresh Water Load Line
Loaded Displacement: The weight in Tonnes of a vessels hull, machinery , spares, cargo, fuel, water and crew when a ship is immersed to its Summer load line.
Locking Pintle: A Rudder pintle specifically designed with a restraining collar to prevent the rudder from displacement in, for instance, heavy seas.
Loll: Also known as the Angle of Loll occurs if the centre of gravity is allowed to become above the centre of buoyancy. The vessel will “Loll” over until the centre of gravity is in line with the centre of buoyancy. If, by design, or cargo loading this cannot happen the vessel will simply capsize. Particularly significant with such things as a ships crane when the centre of gravity will instantly move upwards when a weight is lifted from a hold. The centre of gravity of the mass will shift from the bottom of the hold to the tip of the jib in the time it takes the crane to take the weight of the load.
Longitudinal Bulkhead: A bulkhead that runs from forward to aft as opposed to transversely which is across the vessel.
Luff: Opposite to Lee so it is the windward side of a vessel, building or land mass.
Luffing: Is the vertical movement of the jib of a crane, hence a “Luffing” crane is one whose jib can be moved vertically, as opposed to a “Chuffing” crane which is one that won’t move at all.
