Cheers Joe,GREAT painting scheme Si..looks like the acrylics are working out in your favor..
I’m having some success. It’s all a learning curve as I’ve pretty much always used Tamiya paint.
Nicely balanced Si, I really like the way you terminated your green and brown at the roof top leaving the base yellow to snake its way through them. Once you get the dapple on I'm sure it will really "pop"! Cheers Rick H.
Glad you like it Rick. I tend to just go with the flow on my camo...works for me:smiling4:
Si,
The paint work is top draw, looking forward to watching this progress.
Cheer mate:thumb2:
Si,
The paint looks to have gone down as it should, I am useless at all this pressure and paint flow and mix it like milk stuff these experts on here use. I mix so that it looks like a drop of water going down the window, then start at 20psi and work from there either up or down a pound or two then work up the mojo on an old 48 scale phantom fuselage as a tester part. Not so sure about the stance of the commander, I have been photo'ed at dances in that position - and the nightmares are still frequent....
Keep up the great work.
Cheers, Mike.
Evening Mike,
I’m very much in the same boat on my airbrush. I think we develop a knack of knowing what won’t work after a while.
Commander is a groovy bugger ehh:smiling5:
Thanks very much mate:thumb2:Looking very good Si
Cheers Ross :thumb2:Nice paintwork Si,
cheers
Ross
Thanks Paul....you ever make these in your scale?The finish looks excellent. PaulE
Well a ma-hoosive thanks you for all your feedback gent, always appreciated:thumb2:
Update inbound!!!
Tracks......pigment now dry and dry brushed with some shiny bits.
Then back to the camo. Well I’m happy to admit it went a bit pear shaped but I think I’ve sorted it.
I used a PE mask to do the dappled ambush pattern but it wasn’t the right one and I made a real bad job of it.
So after a bit of pondering, I sprayed over what i had done, then came up with a better plan:thinking:
I took a rubber band and chopped a few peices off, glued them to the end of a BBQ skewers and made a rubber stamp. I used some foam stuff I got from Hobbycraft as the blotter....and off I went!
I’m very pleased with the result. When viewed from a distance it’s actually quite an effective camo, I can see why it was used. Obviously It needs weathering so it doesn’t look so in yer’ face!
I’ve got the wheels painted too so nearly ready for it all to go back together.
I hope you like, thanks for looking
Si
