Simon's Revel 1:24 N-1 star fighter
forgot how it highlights every blemish, 1 or 2 bitz ill need to clean up but all in not to bad
more when i have it
simon
Quick up date painting continues silver mainly!!! (or variants of)
tested one set of leds and soldered up one set of rings (badly) …
cock pit mando and kin coming on .. okIMG_3198.jpegIMG_3199.jpegIMG_3197.jpegIMG_3200.jpegIMG_3201.jpegIMG_3202.jpeg
more over the weekend if I’m allowed (joke)
simon
Ok bit more soldering today and chopping out bits of plastic, so i put together a few more led’s 8, 4 a side. Glued them in to the rear truster covers added the pointy bit (Temp) checked they worked and then trialled the whole assembly in the dark seems to be working ok, other side to finish off then i need to cut a couple of tracks in the wing bottom to allow for an interference free fit IMG_3205.jpegIMG_3206.jpegIMG_3207.jpegIMG_3208.jpegIMG_3209.jpegIMG_3211.jpegIMG_3212.jpegIMG_3213.jpegIMG_3216.jpegIMG_3219.jpeg
All just temporally fitted so once i get everything seated properly i can start assembling in earnest
simon
Bit more done today seen as how the weathers is so miserable… soldered up the 3rd engine and trialed it, also managed to fit the wiring into the very tight space between top and bottom of wings involved stripping off the insulation and cleaning out a couple of small groves even managed to get mando and Grogo finished seated in there cockpit, sorry pictures are not in order IMG_3224.jpegIMG_3226.jpegIMG_3227.jpegIMG_3233.jpegIMG_3232.jpegIMG_3230.jpegIMG_3231.jpegIMG_3229.jpegIMG_3223.jpegIMG_3222.jpegIMG_3228.jpeg
this is the way
simon
Ok last 2 for the weekend, both wings and trusters trial fitted 20240609_203138.jpeg20240609_203127.jpegits starting to look good, hope to start perminant fitting over the next day or 3!!!
simon
HI SI yes fittin them LED's in certainly brings your model to life an it looks great very well done sir am followin to the fininsh
chrisb
