Well this is the finished article
Made a few additions
Little bushes made from garden twine dipped in PVA then in the foliage mix, held in place by dribbling superglue on the stem which makes it hard and glues it in place almost instantly.
The little flowers are made from unraveled garden twine and used a grassy base, the flowers themselves are a paintbrush bristle dipped in PVA and then the end dipped in ground up pastels (so you can make them whatever colour you need) then just poked in the centre of the grass after cutting to length.
the little areas of reddy-green lichen is just twine again coated in PVA then a scatter sprinkled on it ... when dry just cut to length and stick to base in nooks and crannies to give a flowering lichen effect
here you go
one shot with a couple of vehicles plonked on.
here you go
