Right, I'm after a type of modelling material as flexible as modmesh but significantly stronger and definitely harder to tear. Here's a picture of the model so far:
Picasa Web Albums - spenser.h.gray - Jetboil Mod
The model is just the mod mesh bit and it's meant to support the stove's burner and the pan/cup thing on top of that so it needs to be able to support about 1kg when curved round into a circle. It should also be waterproof.
Options that I've looked at so far:
Bacofoil Thick- Just not up to the job, much to flexible and becomes crushed under the weight of the stove and cup (with it folded over 3 times, mod mesh fixes this problem but then becomes very easy to rip).
Cutting out a paper template and laminating it, then cutting slots in it so that I can fasten it together like that (paper fastener could also be used, I'll get some A3 tomorrow from school and draw up a template, then borrow the art department's laminator).
Anyone got any ideas what material could work well here or indeed a method of making bacofoil work since I've got a huge roll of that!
I'm still at school and this is for coursework so anything a school might have is also going to be a welcome suggestion.
Thanks in advance
Spen.
Thanks in advance
Spen.
