OK advice needed. Have had a disaster with my Spit XVI. Started this back in April, and while it was a problematic build pretty much from the get-go, things took a turn for the worse when my wife dropped something on it in a cleaning frenzy. Result:
You can see also the trouble I'd been having with the wing root, as well as my pride & joy of this build, the cockpit, which seemed to have worked really well...
So, what I want to ask is, how recoverable do you think this is? The fitting of the engine block onto the fuselage mounts was tricky even before the breakage, and trying to dry-fit it as it is reveals something of an issue that I'm not sure how to resolve...
As you can see, the whole engine is way out of whack with the rest of the plane, and no amount of fiddling seems to get it all to line up. I'm loathe to give up on this - but at the same time, I really don't want to waste ages and ages on a hopeless task.
So - what do you all reckon? Cut my losses? Or just man up & get the job done?
(Oh, and that very front piece is upside down, too!)
