Steve's 1:48 Revell Apollo 11 "Eagle" lunar lander
So a bit more work completed today. So I needed to add some thermal blanket protection to the top of the landing gear.
Click image for larger version  Name:	IMGP0007 (1).jpg Views:	0 Size:	243.9 KB ID:	1260432
So for this I used some Milliput putty which when dry was painted. It didn't need to be neat because the thermal protection was quite rough looking. I have also added some airiels, radar dishes, ladders and cluster thruster bodies.
Click image for larger version  Name:	IMGP0013.jpg Views:	0 Size:	144.9 KB ID:	1260433
Click image for larger version  Name:	IMGP0021.jpg Views:	0 Size:	224.3 KB ID:	1260434
Click image for larger version  Name:	IMGP0020 (1).jpg Views:	0 Size:	254.8 KB ID:	1260435
Now started work on the final bit of scratch building, the thrust deflectors. I first cut out some plastic card to the right size and then put the concave curve into them by laying them over a heated bar.
Click image for larger version  Name:	IMGP0014.jpg Views:	0 Size:	310.0 KB ID:	1260436
Click image for larger version  Name:	IMGP0015.jpg Views:	0 Size:	130.5 KB ID:	1260437
Then just a bit of trimming down at one end to match the shape of the ones fitted to the Eagle.
Click image for larger version  Name:	IMGP0017.jpg Views:	0 Size:	404.1 KB ID:	1260438
Next step will be cover them with crinckled foil, spray them anthracite and build the support frames from piano wire. Should get that done in the next couple of days. Updates will follow but getting close to the end now. Thanks for looking in
Steve.
Well progress has been made on the thrust deflectors but it was a bit of a phaff. I was trying to find a way of building the support frames and attaching them to the decent stage without the need for drilling any holes but all my efforts failed. So reluctantly it was out with the micro hand drill and I drilled 16 holes into the decent stage body, 4 for each set of mounting brackets and ended up with this.
Click image for larger version  Name:	IMGP0022.jpg Views:	0 Size:	240.2 KB ID:	1260697
Click image for larger version  Name:	IMGP0024.jpg Views:	0 Size:	215.3 KB ID:	1260698
As expected I did a little bit of damage to the foil with the drill so some paint touch up will be required at the end.
So I super glued the lower brackets into place into the drilled holes. Next I prepared the actual thrust deflector plates. These were cut and shaped from plastic card. The actual thrust deflectors on "Eagle" were covered with a thermal sheeting so I have glued some screwed up foil to the front surface of the deflectors.
Click image for larger version  Name:	IMGP0025.jpg Views:	0 Size:	192.1 KB ID:	1260699
Click image for larger version  Name:	IMGP0026.jpg Views:	0 Size:	220.0 KB ID:	1260700
Next job was to spray the deflectors with a primer and then glue them to the lower support struts.
Click image for larger version  Name:	IMGP0027.jpg Views:	0 Size:	270.4 KB ID:	1260701
Next job was to measure and cut the vertical top support struts. These really stiffened up the whole structure.
Click image for larger version  Name:	IMGP0028.jpg Views:	0 Size:	265.6 KB ID:	1260702
So the finished thruster deflectors now look like this.
Click image for larger version  Name:	IMGP0029.jpg Views:	0 Size:	259.3 KB ID:	1260703
There is no doubt that these thrust deflectors have really improved the overall look of the model. In the picture below I have circled all the scratchy built stuff and added a circle on the top right which is where I need to build an additional airiel that is evident on "Eagle" but yet again not included in the kit. All that's left now is to add remaining thruster cones, tidy the model up, varnish and add decals. Thanks for following.
Click image for larger version  Name:	IMGP0029.jpg Views:	0 Size:	303.7 KB ID:	1260704
Thanks Paul. Knowing your skills as I do that compliment means a lot.
HOUSTON ......WE HAVE A PROBLEM.
Well why am I not surprised with this kit. For some reason unknown to man Revell decided to only give one of the astronaut figures a life support pack. Not quite sure what he was expected to do on his EVA.
Click image for larger version  Name:	IMGP0031.jpg Views:	0 Size:	293.8 KB ID:	1260796
Click image for larger version  Name:	IMGP0030.jpg Views:	0 Size:	395.1 KB ID:	1260797
So its out with the milliput. There is also a terrible seam line on these figures. I cannot go in too hard on the sanding process for fear of destroying the suit detail. I wil do my best to blend them in with putty etc but dont want to spend too long on these. I have made a start on the life support pack.
Click image for larger version  Name:	IMGP0032 (1).jpg Views:	0 Size:	158.2 KB ID:	1260798
Click image for larger version  Name:	IMGP0033.jpg Views:	0 Size:	156.5 KB ID:	1260799
Thanks for checking in.
Unbelievable that only 1 astronaut had the life support pack, was the naked one supposed to be inside the LEM?
Luckily I didn't have this problem - no figures in my kit.
Yes he was intended for inside the LM Stefan. I would have still thought he should have had a life support pack on because according to available information, even though the LM was pressurised during decent, the astronauts were suited and booted in the event of an emergency situation . arising. Should be an easy fix.
The final bits are going on. Getting back to the missing VHF aerial. I made the main frame work using piano wire which was stuck to the model using CA. When dry I used a small amount of clear PVA on the attachment points to give it more strengh.
The actual aerial is very thin 4 pronged affair so for that I used thread soaked on CA. I made a small frame work of cocktail sticks and made up a cross of thread. I then just added CA to the thread which made it rigid,
I then just cut out the center "cross" bit which was pained and added to the model.
And the last jobs were the white strips were added around the windows, for this I just used paper as the model doesn't come with any decals for this, and then finished it with the Gold foil around the main hatch way. So that completes the build process. Finished picture in next post.
"Houston, Tranquility base here, the Eagle has landed."
So I am calling this one done chaps. To be honest I am knackered. It was supposed to be a quick build between Group Builds but it turned out to be more of a challenge. I still cant believe Revell put this on the market with so much detail and important bits, like the thrust deflectors,missing. Please dont get this kit mixed up with the later and much more detailed release. Here are just a couple of the finished LM. More will go up in due course in the competed section. Thanks for following.
Thanks Stefan. Thanks again for the files that you sent over on the colour scheme of the Eagle. They were instrumental in the planning and painting of this model.
Thanks Ron. Yes not my usual go to topic but an iconic vehicle that invokes many happy childhood memories from the space race of the 60's
