Steyr 1500 mit Flak, Tamiya, 1/35
PaulTRose
Well-known member
next things on the bench.....
must have bought the Steyr at a show cos it has a Beatties price tag on it..........................and once i looked in the box i find its missing the clear plastic for the windscreen and the mesh for grilles, both easy fixes
got a 20mm flak gun for it to tow
I imagine the Flak 38 will be quite fiddly.
Nah, it’s an old Tamiya kit, so it’s simplified and with relatively large parts, but they should fit well. (I’ve never built it, but I have built a couple examples of Tamiya’s Flakvierling. I doubt this one is very different, construction-wise.)
So are you dragging it or carrying it. PaulE
definatly dragging
thought id make a start on the flak gun first, knew it wouldnt take long but it only took an hour!!
wheels not attached cos i need to paint them seperatly, and ive not attached the front shields since im planning a splash of camo whilst everything else will be dunkelgelb
it was 'new tool' back in 1978 whilst the Steyr dates from 1988
for the first time in ages im doing a kit that im enjoying so much i just want to sit and build, build, build!......typical Tamiya. going together with no drama......of course since today is a 'working at home day' sure helped ;)
Rupert seems ok but Otto looks like he has nodded off on duty and will be heading for the Eastern Front
not sure if i will use the figures anyway but thought id build them for the practice
been having some problems spraying the camo.......this is the third attempt and im still thinking of chucking it in brake fluid to strip it and start again!.............not happy about how the brown seems to drown out the green
i know why, i think i need a new nozzle for my airbrush so had to break out my old Aztek for this 3rd attempt, i havnt used it for years, its a different knack to a 'normal air brush
going to leave it til tomorrow so i can look at it in daylight to decide if it gets stripped or clear coated so i can put a wash on it
Looking good paul ,before stripping it maybe its worth going over just the green parts with it lightened slightly ( a few drops of yellow) to see if it gives a bit more contrast with the brown .
i was thinking over going over with something lighter than the olivgrun.......maybe Russian 4B0 green.......two-tone it.......will all blend with a wash
I'm in Paul.
Pretty sure I remember someone doing the Flak in the back of a truck, like the look of the gun itself.
Will sit in the corner and take notes on the use of the 4BO:nerd:
so rather than airbrushing it again i went old school and used a hairy stick :smiling6:
when i airbrushed it i did the green, then put an edge of brown either side,.....i think the over spray from the brown drowned out the green, so i used a flat paint brush to go over the top of the green, taking away the overspray......hope that made sense
the wheels have had some pigment added in the treads,,,,,vehicle has had some dark wash inside and some mud added to the floor..........outside has had a oil spot filter
im now going to leave it well alone for a few days for the oil to dry before final assembly and a matt coat on top
Paul,
that's looking really good! - the Steyr is one of the Tamiya models which maintained their reputation - going together well, and with nice detail - I looked back in my archives & found I'd made this in late 2017. I used some Eduard mesh, and added a few extra rifles to the carrying clips, otherwise OOB, using the DAK decals. One of those models where you can concentrate on the finish, the fit being worry-free!
