Suck, Squeeze, Bang, Blow
PaulTRose
Tattoine
Paul
Tattooine
couldnt find a suitable place to put this wip......so its gone here since its a car engine lol lol
at the minute im a bit restricted model making wise
my compressor died 2 weeks ago and i cant afford a new one at the minute, too many other things having to come first
which means anything that needs air brushing is on hold.......such as the Brumbar.........my modelling for a while is either rattle cans or hairy brush ................................or no paint at all!
so im going to start something that requires no paint
its an Airfix 'Engineer' kit of a 4 cylinder internal combustion engine............basically you get all the bits to make a see through inline 4 banger which is powered by a small motor so you can see the crankshaft rotating, pistons and valves rising/falling......the spark plugs fire.....all in slow motion of about 30rpm......theres even sound!
and for those who dont know how a 4 stroke engine works the clue is in the title
suck......inlet valve open, piston at bottom, fuel/air mix sucked into the cylinder
squeeze.......valves close, piston rises, squeezes the fuel/air mix
bang......spark plug fires, 'explosion' pushes the piston down
blow.....exhaust valve opens, piston rises and blows out the gases
i used to work for a certain japanese car company and a gang of us were on a week long Technology course........part of it was a trip to the engine plant on Deeside......in reception there was a beautiful cut away engine where you could rotate the crank and see everything moving.....the guy teaching us didnt know how an engine worked!!!!....i casually dropped in 'suck, squeeze, bang, blow' and got a funny look.......ended up having to explain to the group how an engine works
i think this one might be fun since theres no painting and its a subject i know
to give an idea of scale, here is the crankshaft, manifold and fan with a pot of tamiya paint for size
cam belt cover, cylinder head and rocker cover
engine block
valves and dipstick
pistons and con rods
the 'starter motor' that drives it all
power/sound pack and spark plugs
bag of screws and head gaskets and valve springs
Cool I'll tag along and watch this one.
This if a fun little build made one up for one of my sons. that is right into cars when all up and running it is really effective
A few years ago I asked my wife what she would like for Christmas, "A VW air cooled engine to tinker with." was her response (she's a diesel fitter). Not having the cash for the real thing this Airfix kit was a cheaper alternative, it's still in the box unopened.
to be honest i think i could have put this all together in 90 minutes but im enjoying it so much im going slow
cylinder head........valves are in, cam shaft and rocker arms fitted
head attached to the block........rocker cover on the head.........timing belt on and cover over it all......starting to look like an engine now..........its an 'old fashioned' engine cos that grey thing on the right is the dizzy
water pump on, fan and belt on, 'starter motor' on
the end is in sight, not much more to do
Well done that looks a great little project to do with the grandchildren whilst explaining how it works.
