Felt like a change from armour so thought i would try something ive never done before.
The first ship model for me so though i would star off with a lengendary WW2 battleship.
I was expecting alot more in the box for some reason (there are only 8 ish sprues iin the box) but what is in there is good quality from a kit i believe was first made in the 1970's. The kit can even be made motorised if thats soomething you wish to do.
I started off with a good read of the typical well laid out tamiya instrustions and set to work.
I primed the deck and when it was dry i then sprayed a couple of coats of vallejo model air wood.
Next step priming the deck guns, the gun barrels were sprayed in vallejo german grey and the gun housing in dark sea grey
The guns were then glued into their movable psoditions on the deck, i should have pianted the sea grey above the deck around the guns before i glued them in place but i can still get to them so it should cause much trouble.
