Hi Luke. I use a Tamiya airbrush, it's adequate in the same way that an old Toyota Corolla is an adequate car. Reliable, tough, easy to use and forgiving, but it's never going to be as fine or capable as one of the high end airbrush specialist brands. I use enamels through mine and have never had an issue with the airbrush itself or it's compressor (just crappy paints).
I think there are two distinct types, the Basic Sprayworks and the Sprayworks. Both are double action and gravity fed; the latter has a more capable airbrush I believe. Best to do some online research of reviews.
Where in NZ are you Luke?
I don't know if they have teflon seals or spares. If I were you, if I had hte funds, I would look a little higher. I exclusively use Iwatas, and my main brush is the Iwata Hi LIne HP CH. However, this is quite expensive, but provides excellent performance, with fine pencil thin lines and wide coverage. The performance beats the H and S Infinity.
This might provide you with a gauge on what people use. Chinese Cheapos are great as well for people on a budget
Any slightly cheaper iwata brushes you would recommend, desirably around the $200 mark
Sure, the Iwata High Performance plus, you can get that below the 200 mark on ebay, great airbrush, not on the same level as the Hi Line HP CH, but definitely brilliant performance. I believe Brett Green uses this airbrush. This airbrush is directly a step down from the Hi Line series. Below that is the Eclipse series which you could get for really good prices on ebay. The revolution is the cheapest, but if I were going for an Iwata below 200, I would definitely go for the Hi Performance plus
I would recommend this one
http://www.iwata-medea.com/products/iwata-airbrushes/high-performance-plus/hp-c-plus/
Cheers, John
21Thanks for the advice John, i'll definitely look into it.
