Looking really good...... Have you thought about browsing through the ladies tights section for you carbon weave
You know that you have to try them on, just to check the weave pattern of course\ said:Yeah I did actually. Problem with that is its stretchy, and I need it to be taught. Also I'm pretty sure that it's quite hairy in comparison to meshing or netting material.
I think the two Japanese fellas in the white and yellow shirts are looking to see if they can spot the Carbon weave ??? They look none to sure about it.\ said:I had a look at the site. After looking at my reference pics I can say that I'm feeling a lot better about leaving out the carbon detail. You can barely see the finish on the real car so I think we are Ltd with the realistic detail were able to display on a model of this size. If it was a 1:10 scale I'd be pursuing the carbon finish.
If you look at the picture below you can clearly see that the inside of the body just looks a matt grey. I'm sure if you went right up close you'd see the carbon weave but I'd have to be looking right on top of it to see it.
