Well, here we are at the end of day two of this build. Really disappointed the the finish is so bad due to airbrush issues but I will crack on regardless on this one. The grey is on and it has had a filter over it. This was then gloss coated and decals added. Tomorrow it will be another good gloss or satin coat and then I will start the exterior weathering which I hope will rescue it a bit. There is a bit of modulation which the gloss coat hides in the pictures but as I was having to strip and clean the airbrush every ten minutes, my heart wasn't in it.
Still, it has been a long, long time since I have reached the decal stage on a model so that at least is good.
And finally, one on a MiniArt building I did some time ago. As usual, it is a tad over scale I think the door is about 8 feet high in scale! But, if I do the figures, this is where it may end up.
