tanktracks monogram sherman 4 hedge cutter
does anyone know if you can get 1/32 tank crew figures as the ones in the kit are American I have 1/35 ones would they do or are they too small ?
My opinion is will be too small...anyway you can try to build a figure without glue and show on front of the Sherman....your Kit is old, and sometimes the scale isn't exactlly what they said... :oops:
Hope you have luck!!! ;)
Looking good Steve. Are all those sand bags included in the kit or are they aftermarket or scratch built?
Gern
nice build Steve , do like the look off that one, and seen to be going together , well , like the sand bags as well,
have fun weathering them,
what type off men were you thing off using , as if there moving beside, the tank you could down set the tank a
little and have like a bit off mound from were the tracks press into the ground, and that would raise up the men
about 5 mm or so and if there ,kind off stooped over running , don,t think you would pick it up, :rolleyes:
thanks Monica for the ideas , I am doing a "bocage " type scene and I am working on the base as the paint dries on the tank I plan to use some Normandy troops from dragon following the tank through the hedge , and as you say with the tank in 1/32 and the figures in 1/35 I will have to be careful that they don't look too small
I have found some airfix 1/32 British soldiers that may do if they a made well enough , i have measured a 1/35 soldier to the 1/32 American ones in the kit and they are definitely a bit bigger :eek:
those are weaston plastic soldiers in 1/32 , iv ordered a set if airfix 1/32 which I hope work the same as the stand ins
looking good Steve, i do like it, has alot of interest and so much you can do with it,
Im not the best to comment on scale, but to me the figures like fine and well painted,
if you still feel there a little short , sink in the tank a little and then rise up the men
or place them were they would natural be in a higher spot :rolleyes:
looking good the sandbags on the this kit look superb..and nice idea on the base going to look top
