The Seasons's Dare.
Looks awesome Polux great job with the Scale Model shop
Like the well piece too, what is that black stuff you used for road, is that normally something for the roof tar with stones?
Cheers Richi
both look great Polux,
do real like the weathered look of the timber on the scale model shop,
and the well is a nice layout as welll,like the use of real stones to add to
the bank,
good progress on both, ;)
Cheers Richi
You are a crack Richard!! Is exactly that!!!
Time a go I bought a small wood hut, and the roof was made of that.
The texture is perfect for a small stone way. I need only to add some colour and lights ;)
looks superb,Polux,the coloring of the wood with the rust from the nail,
and plus adding the nail,well done,
do like the color you have used for the moss as well
looks great, :D
Went through whole thread and an impressed both with your ideas and work. Nice to challenge yourself sometimes instead of just plodding along from build to build. I'm kind of in the same frame of mind at the moment my self, before I would start something then lose interest and not do anything model related for months sometimes longer, but now belonging to this forum has reignited my interest and now I work at a fairly steady pace. Having others of like mind to share with can be very inspiring............Jim:)
I had a similar experience timr ago Jim.... I'm glad, if you are happy on this forum!
Let's modeling ;)
SPRING
Hi all!
I have been working on the grass...... Now I have to add all the flowers!
The narrow looks very dark and brown.....but is wet yet, I added a pigment fixer, I suppose tomorrow will change a bit once dried O_o
And I started with the well...as well ;)
Thanks for looking!
looks great Polux,the colors are nice and lush, ;)
what length grass did you use ?
Hi Moni.
I used this product from NOCH :)
Is excellent and really easy to work as well.
Anyway I added some acrylic greens and a matt varnish coat to complet the colour ;)
Thanks for your comment!!!
PS: you can see the reference and the size writed :D
ta Polux,
II did think it was the 8mm to 10mm long static grass,
will need to get some of evilbay as most hobby shops don't keep it, ;)
as i have been using the 3mm to 5mm,but that looks much better,
Thanks Moni And Richi ;)
I'm a bit afraid! Maybe is so big for the small base. Seems to be a better item for a bigger scene.....with a tank or similar :confused:
