Hi all, have spent this afternoon putting my Tiger 1 Toon tank together and want to spray it panzer gray not yellow, is this the name or is it something specific, might need to order some as this is my first military vehicle.
Thanks
Thanks
Thanks„Panzer grey” is the common English name for the dark grey colour that German military vehicles were painted in until early 1943. Any model paint that says it’s „Panzer grey” should do.
Thanksits called Dunkelgrau i believe.....the modern RAL Classic number is 7021
Thanks for that information.On Tigers? To spread the weight as much as possible and so prevent the tank from sinking into the ground.
The Germans began using this kind of suspension on their halftracks, then adopted it for the heavier tanks (everything designed after the Pz.Kpfw. IV, basically). Nobody else ever used it, though, because its drawbacks outweigh its advantages: mud builds up between the wheels and can cause them to jam, especially if it’s freezing, and maintenance and repairs are a nightmare: on a Tiger I with the original wheel layout, to access one wheel you need to change, you may have to remove up to fourteen others. Count them:
See which ones you’d need to take off to get at the third wheel from the left on the upper row :smiling3:
By the Tiger II, the Germans had realised this as well and simplified it into two rows of double wheels, which makes maintenance and repairs easier — but you’d still have to take up to five wheels off to get at an inner one.
