Tips on silver/metal finish using a brush?
morning all
right i have come to the conclusion that i will have a go at my Sabre will a rattle can primer and a metal finish silver also from a rattle can.
mainly because I found a unopened can of both in a house move so will test them and see if they haven't gone off.
anyone got any useful and easy to follow tips for an absolute novice and his 7 year old apprentice on how best to go at this.
cheers Paul
Sounds the easiest to me Paul . Ive done a lot of silver finishes using just this method. the best advice I can give is use short bursts of the aerosol , make sure youve got plenty of ventilation and a couple of masks ,and have a practice first. If youre too close it will be too thick and wet and will run , too far away and it will dry before it hits the model and result in a grainy finish, just have a bit of a play first, I'm sure youll quickly get the hang of it. cheers tony
Tony's spot on, nice short bursts, start spraying to one side of the model and sweep the spray across it, don't stop spraying until you are past it. Have a practice on a plastic bottle. A few thin coats are better than one drippy thick one. If you have problems you can get a reasonable finish with a brush. Here's one I am in the process of doing. I used a one centimetre flat brush and thinned the paint until it was like milk. The front panels are silver with a little drop of black in the mix and the fabric on the wings and fuselage are aluminum with a drop of white added. I did about 4 coats of each. Don't go back over what you've done and its fine, it will look blotchy at first bu t comes up ok.
