Typhoon TK-17 based on Engel's Kit
That's all, I post all photo of this project since last post from me :music_too
If you want any explain about don't hesitate to ask ^^
New task was done on my shipyard yesterday. New leak and bubbles hunt and I found a new source of bubbles...
On this picture, we seeing the result of repair. I proceeded with same method than before, drilling + filling the hole with resin and microballooon. I'm waiting to get dry before retest.
Then, I decided to remove external part of bow thruster. This is a really piece of Sh...t !
I will remake a new one If during her first sea trial she has some problems to do some manoeuver. I keept motor in place, perhaps I will need him later...
After that, I was occupied by port reactors inlet. Engel put them on really wrong localization. This is a very difficult task because, there is two possible positions and Due the fact that i don't have any photos of TK-17 in dry dock, so I put them like TK-20 but...
Localization is correct, now I must proceed with grids.. that will be Rock n' Roll !
Hi Wis
THX a lot. It seems that U will be the M A S T E R !!!!!!!!!
Hold on!:respect4::respect4::respect4::respect4::respect4::respect4:
Heiko
I tried to improve as much as I can my models
I'm glad if my work help you or give you much motivation to build your own model !
:regards:
Hi Wis, toooo shy:smile1:
Two questions
Will you comment this workload of photos?
Where did you got the aluminium linkage execution http://www.subressources.net/ImagesRotators/Vig/TK-17/TK-17_-(384).jpg
Rgds
Heiko
:strong:
euh well, edit seems to be noty possible so ask me question like you did and I will try to anwser ;)
the "Kabelverschraubung" (presse-étoupe, sorry english-people I don't know the word in your language... rusty I'am) were done with Metalworking lathes by me; thereis two Drive Shaft Sealing Ring 4-11-6 and one ball bearing on it :
Today on my shipyard, reactor cooling exhaust !
First, make a large hole on hull were i'll put a grid...
Horizontal pieces...
Inside, some rigid structure to obtain an stronger structure..
vertical pieces wil be add later
today, end of work of reactor exhaust grids
Inside, there is still some work to do to get a better looking... just another sanding session :P
After sending hull, there is much better looking !
Globaly, I'm pretty happy, that look not bad ! Of course before painting this models will require a lot of corrections ! :thinking:
I dont check in here often as I follow your build elsewhere, but once again a superb build and modifications to the original. You've raised the bar so much I bet you have put a few people off build an Engel Typhoon kit! :respect2:
Totally agree! :sobbing::sobbing::sobbing::sobbing::sobbing:
Heiko
Well... i'm blushing
Anyway...Today, I continu to add details on port side on the upper hull. Handrail, bolar...etc
Drilling on starbord side, now sanding do fit with grid's size
