Under Construction...1/350 Airfix H.M.S. Triumph...Nuclear submarine
spanner570
I've just finished this, but here are the build pictures, prior to adding the silicone.
I only needed the upper hull and I dispensed with most of the periscope gear etc.....So I was left with a grand total of nine pieces to glue together!!
Photos 2 and 3 are obviously the wrong way around........
The first stage was the kit construction and painting.
Then I fitted the hull into some polystyrene
Then a layer of tile adhesive.
A layer of polyfilla was applied to form the basic waves, ready for the silicone
Then, as you know, I always use cheap acrylic paints to cover large areas such as the sea. This I built up with various shades of blue/ green....
I intended to put this writing between the pictures, but couldn't figure how to!
Ron
Nice one Ron. Simple and effective.
\ said:
Nice one Ron. Simple and effective.Ian M
Thanks Ian, I've now added the silicone and took pictures of the finished boat, so I'll post them in 'Completed' soon.
Ron
Thanks Paul, Glad you like the progress.....a bit short and sweet, but a challenge nonetheless.....
Ron
Looks like another classic Ron build in the making
Ron to write inbetween the pictures, after you have uploaded them put the curser ( pulsing stick thing ) behind the picture you wish to write infront of then as you write the piture moves forward infornt of the words
Thanks for your post Joe and also thanks Ian for your information. I appreciate it.....
I've added the silicone and finished the submarine. The pictures are in Ships and Boats - Completed Submarines.
Thanks to everyone for your input during the rather rapid construction!
Ron
great build Ron, i do like how you turn plaster into water, with paint and silicon well done
