So, I've been back doing this for a couple of small models now and tried to learn something new with each. Except filling, that seems to be a PIA and looks horrible because the Humbrol product that was at the local shop doesn't seem to be particularly easy to manipulate and I don't have sufficiently smooth enough sanding equipment. No problem though, I picked up a 1:48 scale box with two planes in it which is new tooling, so there shouldn't by much need for filling - I can get on with the other stuff I've learned!
http://www.airfix.com/aircraft/1-48-scale-military-aircraft/supermarine-spitfire-mkvb-messerschmitt-bf109e-dogfight-doubles-gift-set-1-48.html
Didn't think it worth putting a picture of the sprues up, I'm sure everyone's seen an Airfix Bf109 before! Not a lot of flash, looks pretty good, no complaints at all!
So, this isn't a gift set, so I'm using my own paints. This is genuinely the paint instructions for the cockpit and pilot:
Lesson learnt here was that if the pilot comes with separate arms, paint them first, then glue - it's a lot easier that way, anywho I have a tiny brush now so that's not a bad effort.
The black though, how dull is that?!?!? I've heard of this dry-brushing thing, let's whip out the Silver and give that a go:
Better, but still pretty dull. Anyway, I'm not going to fuss about this one as this is just practice for the Spitfire also in the box! On to putting the plane together
Ar$e. This did not fit well at all, one wing in particular has a HUGE gaping hole on both the upper and lower parts of the wing and any attempts to file down is making it worse! Out comes the filler... This time round I used some liquid poly to properly thin this down, so much I could use a brush to apply, the result is better than my previous attempts, but I know it won't be great as I cannot get a smooth surface as a result.
Anyway, all filled - now the fun bit - AIRBRUSH!!! Firstly, everyone does a pre-shader - or black lines as it turned out to be!
I never got the point of this step, and as you can see, I need more practice as I cannot draw a straight line! Anyway, I painted a white stripe at the back and then I saw what the point of pre-shading was, it doesn't come out on a photo, but there's a "depth" created by the colour underneath, very subtle but noticeable.
Underside painted, the depth again works really well with the panel lines, as does having a airbrush I can control! This is now drying. Which leaves me to the paint instructions:
There are only two colours, which is nice and easy, but it's not a solid line between the two, it's some kind of jagged edge, nice effect, but I'm not sure how to do that. I have some Maskol, so was thinking of the following two options:
1. Lay out masking tape on a table and use a scalpel to create the effect and put that on the plane.
2. Lay down a flat line of masking tape and use a hairy brush and Maskol to create the effect instead
And then airbrush the colour over the top. What would you do to get that effect?
