Using decanted paint in an airbrush?
I've never used decanted spray paint in an airbrush before and need some advise in using it. I'm using Tamiya's acrylic paint and I've already decanted the paint and left it to sit for about 36 hours before closing up the jar (no explosions here). Can someone give some advice on using it? It looks like it's thinned properly (makes sense since it just came out of spray can) but are there other things I need to be aware of before I blaze away?
Ray
I use Tamiya primers like this. I just let them degas by leaving the jar lid loose (but not uncovered) overnight, then use them like any other paint. Like other paint I thin them if required. I really wish Tamiya did their primer in a jar.
Tim
Tim,
Thanks for the reply. What do you use as a thinner? Any retarder or flow improver? I've got several IJN ships to do so I'll be doing a lot of this in the future.
Ray
Hi Ray
Depends on the paint. For Tamiya I use Mr Colour levelling thinners. For others it depends what they are. What paint are you looking to use?
Tim
John,
I'm using Tamiya and I have some Mr Colour thinners so I'll do some spraying tonight. Any special nozzle size I need worry about?
Ray
Not ,something I ever worry about personally. Mine has a 0.2 I think, but general use seems to be 0.3, so yours should be fine unless you want really thin lines.
Tim
