V1 on launch ramp Modelcollect 1/72 Scale
Bigfoot57
Weston Super Mare
Colin
Originally a small village outside of Reading Berkshire called Burghfield Common
As I have been building up my rocket collection, starting with a V2 and finishing with the Artemis, there was one that was missing and that was the V1, though technically not a rocket, it was a primitive cruise missile, should we say? Nevertheless, I wanted to build one, so I got one made by Modelcollect in 1/72 scale along with the launch ramp, well, two actually, which I cobbled together to make one of the correct length so first off, box art and sprue shots along with instructions all two pages of them. What you see below.
So to build this kit took about an hour. I think the V1 was made of four pieces, possibly five. and the ramps were made of two bits. You just joined together the main problem came when attaching them into a coherent line. The original kit only allowed you to build two sets of ramps of four pieces each, which was woefully short, so I used the additional ramps that they supplied for the second set and made a complete the scale length out of both sets. And to stop them sagging after trying various methods I used a 2ft long 1/4” steel rod and threaded the individual ramps onto it
Next came constructing the additional pylons that would be required because of the extra length, these were made from cocktail stirring sticks and 3mm I beam rod from Evergreen determining the end height of the ramp should be 70mm, this being the equivalent of 16 feet the subsequent ramps in between were made to suitable sizes, and then all glued together, after which, once they’ve set, they were then attached to the ramps to form the completed model. This was then painted in a yellow and green camouflage as per the box art, along with gun metal along tops for the joining plates
Next, I built two V1 ones as they supplied two. One was done as a standard V1 with mottled camouflage on top with splinter camouflage on the wings and light blue underneath, and the second one I did as a representation of the V1 that Hannah Reich flew in Operation Crossbow film complete with its little cockpit and all the scorchmarks along the engine and that was basically it
IMG_8520.webpIMG_8531.webpIMG_8533.webpIMG_8534.webpIMG_8606.webpIMG_8644.webpIMG_8562.webp
