This is a British tank, though, so almost certainly the opposite is trueRussian tendency to simplest solution.
I bow to your superior mechanical mind Si, so thank you.I’d go for down as well John. My mechanical mind says so and I tend not to argue with it much these days :tongue-out:
That base is looking very good :thumb2:
Tank turrets are fairly well-balanced, else they become hard to traverse on an incline, so I wouldn’t think it’s implausible for this one to have its gun barrel up into the air. And there will be a turret lock that secures it in whatever position the turret is in when it’s applied, but I admit it would be odd for that to be engaged with the turret at about 10 o'clock rather than at 12 or 6.
Thanks Paul.I would say down as the clutch on the traverse box would have slipped given the weight and momentum of the turret/barrel.
Thanks Paul.Down, w/o knowing traverse mechanics I'd imagine so due to age & Russian tendency to simplest solution.
An interesting reply, thanks .This is a British tank, though, so almost certainly the opposite is true
Years ago, I was talking to someone about the turret hatch on the early Crusader tanks, which sort of slides horizontally backwards. I mentioned that this seemed a pretty good idea, but a kind of peculiarly British-engineered solution as well, and wondered why no other tanks used it. “Because,” he replied, “the catch holding that hatch open is also British-engineered.”
Anyway, I maintain that the barrel up will be more interesting for the diorama, which you can call artistic licence if it turns out to be impossible to have that way IRL![]()
You think so? It’s a kind of milk-chocolaty brown, that IMHO looks not bad at all. But maybe that’s because I like milk chocolateSCC 2 Brown. What a nasty looking colour !
Looks more dark to me lolYou think so? It’s a kind of milk-chocolaty brown, that IMHO looks not bad at all. But maybe that’s because I like milk chocolate :smiling3:
Hi, well I've got some chocolate brown ! and some lighter browns. I'm thinking as It's been abandoned for several seasons the paint might well have faded somewhat .I’m basing that description on the colour chips in Mike Starmer’s books, which are actual model paint mixed to match the real paint. If you want, I can look up the mixes he recommends.
He recommends 5 × Revell 86 Olive Brown + 6 × Revell 84 Leather Brown — these being the enamels, if you were to mix the acrylics it may nor may not end up the same colour. Alternatively, the book says White Ensign Models (now Sovereign Colourcoats) ARB05 is slightly light, but it’s presently unavailable anyway.Now if you have some mixes from one of his books that would be great, I shall look fwd to seeing them :thumb2:.Of course I'm using AK 3 rd gen but having an idea on the colour would be great .
Fear not Wibble , things are in hand, yes that bottle contents have been long gone, its that bottle I use came with a lid. The spray part is washed out every time.Wobble,
I seem to be detecting a theme here, if the driving is so bad in the Russian Army I can reccomend a good driving school 'You Crash 'Em - We Pass 'Em'....
Base looks really good, you had me worried when I saw the WWS bottle (ok for rail layouts), but then you explained it was for your diluted pva, I cancelled Matron....
Wibble
Thanks , I can cross ref those on https://www.modelshade.com/.https:/...shade.com/paint-conversion-chart/revell/36184He recommends 5 × Revell 86 Olive Brown + 6 × Revell 84 Leather Brown — these being the enamels, if you were to mix the acrylics it may nor may not end up the same colour. Alternatively, the book says White Ensign Models (now Sovereign Colourcoats) ARB05 is slightly light, but it’s presently unavailable anyway.
Hi , I've used Chocolate brown from AK 3rd gen , there's so much difference in all of the paints when you view them on Model shade.Beware that if you take paints from a different brand, that are individually the same colour as the Revell ones, you probably won’t get the same final colour when you mix them.
A little research also turned up a Tamiya mix: 5 × XF-68 NATO Brown + 4 × XF-3 Flat Yellow + 1 × XF-1 Flat Black.
And I just remembered I have a bottle of AK 3rg Gen No. 11385, S.C.C. No. 2 Brown. Comparing it to the swatch in the book, it seems to be slighty darker, so add a little bit of a sand colour and it will probably be spot-on.
Thanks mate .Coming on very nicely John.
Thanks Rich, only bought the afv model as it was cheap ! Hope you will post your build.Sorry for being late on parade and missing your build My friend.I got a Rubicon 1.56th Valentine kit for my birthday which makes a mark.9,10 and 11.I loved the Bronco one Nightshift did on youtube.Think you have done a great job John.Looks mighty fine to me dear boy.
