Vallejo cleaning help plz ?
monica
Hi not sure if i have asked this before sorry if i have,
what else can i use to clean Vallejo paint with , still waiting on the order to come from Spain :confused:
can i use windex and water ? :( or some think else ?
any help would be great thanks all
Moni
I use methylated spirits on both my airbrush and hairy sticks with no problems.
Gern
yes - both of those are fine Monica.
What I have for the airbrush, is a wondow cleaner mix 50% with water ( your Windex equivilent) which I blow through the airbrush to clean it. This is what I use in volume as it is a lot cheaper than a/b cleaner. I then use Vallejo Airbrush cleaner for a final squirt through as it lubricates (I also do an initial squirt of this before loading with the first paint of a session). When I break down the airbrush I soak the pieces in ipa and wipe the body with that to clean it.
For brushes I just use water but at the end of every project clean them more thoroughly with ipa.
Rinse well with water to get as much paint out first and DO NOT spray it though, pour it out. Once most of it is washed away, any amonia based window cleaner will take the rest. Or as said meths or iso alcohol. IPA. also call rubbing alcohol in some places.
\ said:
Hi not sure if i have asked this before sorry if i have,what else can i use to clean Vallejo paint with , still waiting on the order to come from Spain :confused:
Moni
Sometimes I use methylated spirits like Gern. Must say I don't use habitualy too... O_o
Ps: can I ask where you buy in spain...?
hi all thank you so much for your help and advice , as i have been waiting over 3 wks for the hobby shop to get it in,
for ordering it from Spain Polax you can off there wed sit i did see alink for ordering
thank you Ian for saying what IPA was ,as that would off been what i ask next :oops: :D
have some paint and real do wont to try the dark art off AB :confused:
