That is fine Ben. Two issues. A bit expensive. No control over the amount of paint.\ said:Sorry if a bit off topic. I use Humbrol spray primer in their can and then Vallejo paints.
Is this OK or should I be using something better.
If you use an airbrush worth considering buying a new primer called Stynylrez marketed by Badger.
It has very good capabilities. In an airbrush you will get better results than a spray can and infinitly cheaper.
If you go to the Forum paint section there is a discussion there on this new primer.
