While I am working on my Do 215 Nightfighter, I decided to start on this
This was a bizarre proposal, by the US Navy for a fighter that could take off & land vertically, on a ship, not needing a carrier deck. There were 3 makers interested, Lockheed, Convair ( with the Pogo ), and Ryan ( Vertijet ).
The Pogo & the Vertijet worked ( sort of ), but the Salmon never took off from it's tail - it was fitted with a Heath Robinson ( Rube Goldberg ) undercarriage for it's test flights. Test pilots just about managed to fly these things - on dry land & in good weather. Just imagine an average Navy pilot, on a ship, rolling & pitching in bad weather!
The idea was needless to say, dropped.
The Valom Salmon is a real short run kit - no locating tabs/pins, loads of flash, vacform canopies....................
The wings/tails are all butt joints - so they need drilling for pins to give strength.................
The tails, in an X configuration need a lot of clean up - especially to make sure that the mating faces are flat
After a session with emery paper on flat board, I was able to drill holes in both the fuselage & tails - and remarkably, I didn't break any drills!
You can build this either as the concept - tail sitter, or with the actual lash-up undercarriage. I'm going for the latter, because it looks so bizarre - photo for discussion only!
