SMS Bot
VMS NO-DMPT Super Glue (CA) Activator Anti-Bloom 200ml AX19
VMS NO-DMPT Super Glue (CA) Activator Anti-Bloom AX19 is a 200ml cyanoacrylate glue accelerator developed specifically for scale modelling. Its advanced amine formula speeds up the curing of super glue bonds while helping to reduce the blooming and frosting that can occur around glued areas.
Designed for modellers who regularly work with CA adhesives, this activator combines rapid bond curing with an anti-bloom formulation. It is particularly useful when working on models where the appearance of the finished glued area matters as much as the speed of assembly.
Cyanoacrylate adhesives, commonly known as CA glue or super glue, are widely used in scale modelling. An activator accelerates the curing process, reducing the time needed for the adhesive bond to set.
VMS AX19 uses an advanced amine-based formulation designed to accelerate CA glue curing. This makes it a practical addition to the modelling workbench when assembling parts with cyanoacrylate adhesives.
The product is supplied in a 200ml quantity and is part of the VMS range of modelling products.
One of the main features of this activator is its ability to reduce blooming and frosting associated with CA glue. These effects can leave unwanted white deposits around bonded areas, affecting the appearance of a model.
The anti-bloom formulation helps minimise these effects while accelerating the curing process. This is particularly relevant when working on detailed assemblies where visible glue residue can interfere with the intended finish.
VMS has formulated AX19 without dimethyl toluidine (DMPT), a chemical used in conventional CA glue accelerators. DMPT is identified by the manufacturer as a carcinogenic ingredient, and this product has been developed as an alternative that does not contain it.
The absence of DMPT is a defining feature of this activator, alongside its fast-curing and anti-bloom properties. It provides modellers with a different formulation from conventional DMPT-containing accelerators while retaining the intended function of speeding up cyanoacrylate glue bonds.
VMS NO-DMPT Activator combines three important characteristics in one product: accelerated CA glue curing, reduced blooming and a DMPT-free formulation. It is intended for modelling work involving cyanoacrylate adhesives, particularly where clean-looking glued areas and efficient assembly are priorities.
The post VMS NO-DMPT Super Glue (CA) Activator Anti-Bloom 200ml AX19 appeared first on Scale Model Shop.
Faster Curing for CA Glue Bonds
Anti-Bloom Formula
DMPT-Free CA Activator
Product Features
- 200ml CA glue activator
- Developed specifically for scale modellers
- Advanced amine-based formula
- Accelerates curing of cyanoacrylate adhesive bonds
- Helps reduce blooming and frosting
- Formulated without dimethyl toluidine (DMPT)
- Manufacturer reference AX19
