Great resource!!\ said:Dave, a wash is made from adding white spirit to the oil paint. The consistency depends on personal choice. There's no right or wrong!
Try experimenting & see how different blends work best for you. IMHO the most important thing is a nice glossy surface - it makes the wash flow much easier & allows any excess to be easily wiped away.
A filter on the other hand is the complete opposite. Essentially it's tinted thinner rather than thinned paint. It's applied to a matt surface to ensure the filter lays on the surface.
The microscopic hollows in a matt coat get filled with the filter, producing the tonal effect. For this reason, I always apply a matt coat to a model before using a filter to protect the paint.
Although not strictly about washes & filters, the link shows an excellent article about weathering with oil paints.
http://missing-lynx.com/articles/other/oilpaintrenderingmr_1.html
Useful vid to show how to make the filter, however, I'd recommend not loading the brush so much, the "puddling" of wash is a problem if you don't catch it all! Much better to scrape the brush on the edge of the jar and maybe put 2 or even 3 coats on. The effect of many thin coats cannot be overstated, its a technique used by artists for centuries, you end up with a deep, rich and complex colour which, when compared to a single colour, is far superior. You can also add more coats to certain surfaces, which creates similar "simulated 3-D" effects not dissimilar to pre-shading and modulation, and generally created contrasting surfaces and colours. I'm making my filters with thinned down enamels now, they dry quicker, don't tend to separate as much. Am currently loving AK interactive for this job!\ said:any good?
Turpentine is an organic substance made from resins, white spirit is an oil based liquid, much cheaper and far less smelly, believe it or not! Also much cheaper. My preference is odourless thinners, more expensive, but much more pleasant to use\ said:I got some oil paints today, two different types.
I bought two tubes of Winston oil paints, Burnt umber and Raw Umber,
Also got a small primary colour set by Steadfast, which had five tubes for £2.99
I have got these small sealable pots, and made up some washes to keep handy, and boy, is it worth paying the extra for quality oil paints!
The winston brand is a thick decent oil paint, mixes really well with turps to make a nice wash.
I then made a white and a mellow sand wash from the steadfast ones, and they're way way different! The oil paint is nowhere near as pigmented, and when mixed, doesn't produce as nice and even colour as the Winston.
So you DO get what you pay for.
One last question, as I'm dumber than a dumb thing, what's the difference between turpentine and white spirit??
