This wont apply to a lot of you big boys but for the benefit of those who have never heard of a wet pallete, here goes.
Some people use a pallet. In short, you place paint on the pallette and add water to thin it, or other colours to create another colour etc etc, and over a VERY short period of time the paint, starting from the edges, begins to go dry and becomes unusable. You start another blob and suddenly need the toilet. You come back and your blob of paint is, again, unusable. By the time you have finished you have probably used twice as much paint as you actually needed as half of it is dryed up.
One answer is a wet pallette. In short its a sponge with a piece of paper on top. You wet the sponge, the water soaks gently through the paper and you use the paper as a palatte. The paint stays moist but not wet. I have no idea about the sciency bit but its awesome anyway, Its that good that you can put a dollop of paint on the pallette, shut the lid and come back weeks later and its sitting there ready to use. Once the pallette is all full up of paint you just remove the top layer and place a new one on. When it starts to dry up you put more water in. Its recommended that you dont use tap water, but then most of use half serious modellers wouldnt use tap water to thin our paints anyway.
So, where do you get one from?
Well, you could buy this one
This is currently on offer, reduced from £11.95 to £10.76. Bargain.
or you could make your own. Anyone who knows me will know that I dont simply go out and buy things when I can bodge something together.
You will need
- One container with a snap fitting lid. I bought two from Poundland. Try to get one as shallow as possible as you will be dipping your brush in it.
- Some baking paper..NOT GREASEPROOF PAPER. The paper needs to be porous. I got an 8 meter roll from poundland.
- A sheet of kitchen roll. I stole a sheet from the landlady.
Put it together and you have something like this
Now, Im going to admit I havent tried it out yet, so I will give you an update later on. But if you search "Wet Pallette" on you tube there are some nice videos on how to use them and how to make them.
You will need
