Wings Palette
Apologies if this has been mentioned before, but there's a truly impressive array of colour profiles assembled at WINGS PALETTE
Hi Matt,there are a lot of profiles there and I wouldn't want to discourage anyone from using them. I would add a word of caution.There are many inaccurate or misleading profiles in amongst the decent ones and I would always try to check any profile with other sources,this applies to any site really.
Hi matt , its a great site and gives a lot of profiles,i have used it quite a bit , BUT as steve says always try and confirm any info if possible , there is usually the source of the info under the profiles ,this can be a good indication of how reliable it is.for example i was looking at some on there the other day and the source credited was Yefim Gordon , a very well respected expert on all things soviet , so i took it as a good indication of its authenticity. cheers tony
