***Richard these models are over 35-40 years old, and have been restored from the broken remains utilising scratch built components or bits from the spares box in many cases,most of the kits are no longer available which prompted me to rebuild them,sadly I have lost my original notes,building instructions,box ends etc in various house moves which makes kit manufacturer identification difficult.
Whenever possible I will endeavour to provide a few details if my memory allows me,if not then details of the real machine are added like the Curtiss Condor above.
I do believe the Condor to be an original ITC kit that was revamped by Kleeware U.S.A in 1=72nd scale.
Most are fairy obscure manufacturers now long defunct which makes them a bit special.
Since Jan 2005 have managed to salvage 200 models,some required a dunk in brake fluid ( thanks Nigel for that excellent tip ) to remove old paint prior to priming and painting,others needed splitting down the seams,to get at rattling bits inside of them which had to be retrieved and re-glued,others just needed a bit of work with some wet and dry and a lick of paint added.
The work has been very satisfying to save these old relics,many of which cannot be replaced.
Barry, I think it would be interesting if you could put a bit of information regarding the model alongside these pictures. Such as Airfix 1/72nd, Frog 1/48th etc.Just a thought, although you are probably like me and can't remember all of them!!
