Xtracrylix Paint Questions
1. On Xtracrylix paints it states "glossy (decal ready) when dry; "Is it really decal-ready? If so, it would do away with a gloss coat applied specially for the decals (which in practice means everywhere if the smaller "no step" type of decal were included);
2. On the thinner it states: " (... fine with water, Xtracylix thinners or Tamiya thinners). Is water really OK? (It's cheap!)​
3. I want the final paintwork to be between matt and glossy — a slight sheen. What varnish should I use (over Xtracrylix paint)?
4. From advice elsewhere on this forum, I will be thinning the paint 50/50. OK?
5. What about the thinning ratio for any varnish that you recommend, and the type of thinner for it?
I have just noticed that Xtracrylix make a satin varnish. Is that what I need?
Hi Steve.
1 I would still apply a gloss varnish over Xtracrylix before decals. At the very least it will give the paint a bit of protection.
2 Xtracrylix is the only acrylic paint I've used often and I always thinned with finest Birmingham tap water (very soft). I also added a drop of Liquitex retardant to the paint cup.
3 I use Vallejo varnish. The satin varnish is exactly that,satin,and should do the job
4 In my experience Xtracrylix needs less than 50: 50 thinning. I'd guess more like 70:30 paint to thinners. You'll have to experiment with this as everyone's set up will be slightly different.
5 I use Vallejo's own "diluant" for their varnish,sometimes with a drop or two of water.
I was going to say exactly the same as Steve on all points!
Thanks Steve, saved me having to think about it!
I've been using this paint on and off and when I thin it I use water but recently I have not thinned it at all, shot it straight through the air brush.
scott
