Yaks ‘Century Series’ in 1/48 part 3 - Convair F-102A Delta Dagger
yak face
Staff member
Sheffield
Here we are , four years after starting this series project and I’m only on the third build of six ! This is the Revell issue of the Monogram F-102 . I originally had the Monogram kit for this but after a bit of research found out it had the wrong decals for the aircraft modelled ( to do with Case X and Case XX wing shapes , bit too involved to go into here) Anyway I found out this Revell reboxing features a revised wing tooling and had the correct decals for the wing shape featured ,so got it and moved the Monogram kit on via eBay . ( the old Monogram decals would probably have given me grief anyway , see the F 101 )
Anyways here’s the box top and sprues , it’s monogram at their finest - lovely detail but not too complicated . The kit has the option of having the Falcon rockets with all their associated trapezes hanging out of the weapons bay but I prefer a cleaner look so it’ll be closed up. I’ve also got an Eduard Zoom fret for the cockpit , mainly for the seat belts as the moulded on ones are a bit faint but I might use the IP and other bits as well. 916D724E-B162-49DD-AB5B-05B8BF64544B.jpegADAD08EE-185A-4223-A09E-62E0DCA3EF25.jpeg086237A5-F497-4521-AA92-7CAC98B03613.jpeg93197AF4-8327-4348-9F61-230C2F640DA5.jpeg
Hi Tony
I look forward to this. Fine looking aircraft. Sounds like a nice kit. Brings back memories as a few years ago a modeller friend sadly passed away and kits from his stash were given to some of his modelling colleagues to build in his memory. I got the Meng 1/72 Delta Dagger flown by George W Bush during his time with the Texas Air National Guard.
Hi Tony
Cheers jim , yes its a fantastic looking bird isnt it , unfortunately it was one of those that looked a hell of a lot faster than it actually was ! Surprisingly large in this scale too , cheers tony
Made a bit of a start on this today , got the top and bottom of the wing together , needed a lot of clamps though as its such a big wing 32B09651-EDA0-405C-99C1-D0691263B801.jpeg
Got the seat together and the main colour on . Ive also ground off the moulded on belts ready fir the pe. Ive got some colour on the cockpit tub too and been looking at the instrument panel. The kit panel is very finely detailed and with a lot of patience and a good magnifier it could look great but seen as ive got the pe anyway im going to save my time and eyesight and just use these.C7ABCECF-93C6-479E-9536-04664C8CDEFC.jpegDB981BD2-894C-4BB6-98A3-8CF6195EAF61.jpeg95297AC9-4CCF-40FC-8FF0-9ABF4A47ED7B.jpeg7434DC04-6A56-42A0-8A60-FC10F92A9FC4.jpeg
Seat now painted and pe belts fitted . The cockpit tub Has also had some paint and the pe side panels and instrument panel have been fitted and the seat put in , the whole thing having a Dark dirt wash to give it a bit more depth .The pit is now complete and ready to go in the fuselage . 664FE3C4-DD8A-4F5C-91BB-7A65B2B5FA3B.jpeg4DFA1D6C-A48C-4860-9643-4657F175C5BE.jpeg6A4EE667-2782-4A07-A24E-4F77DD60930D.jpeg9E346EEE-204B-414A-A664-916379B00BAF.jpeg68541FE3-6456-44E1-B998-DE84EAA66FFA.jpeg29C02B4E-7871-4DD1-9EF7-FD0BE71E1AC2.jpeg
Got the fuselage halves together , nose cone on and the huge wing fitted .The intakes and splitter plates have been fitted to the fuselage and filled and sanded. Its all setting now with plenty of tape to hold the joints together. Its a surprisingly large model in 1/48 as can be seen by the 1/ 72 Spitfire next to it . As I decided to have the missile bays closed the next step is to fit the closed doors section under the belly . B766D06B-119B-451D-9BDF-F14B6F655B82.jpeg
Looking good Tony, loving your Century Series builds. I like the F-102 and later F-106 shapes. I have a 1/72 Meng F-102 kit so will watch your build of its larger scale cousin with interest.
Cheers joe , i know its been a long time since the voodoo ! Its a fantastic looking aircraft and in this scale quite large . The old monogram tooling is still a great bit of moulding , lots of nice detail although the fit does need a bit of fettling here and there . The open missile bays are excellently detailed , bit of a shame I’m leaving them shut ! Cheers tony
Been so busy with work and other stuff lately so havent been in the shed for a long while , hence the long interval between posts on this one. Anyway yesterday i got the pre shading on and today gave it a light coat of ADC grey ( Air Defence Command) .As on the f101 Voodoo , I used vallejo model air 71/046 which is a good match for the adc grey . BF11C3EF-21F5-4765-875D-A970CE09CDFE.jpeg58B51FF7-BC71-4677-A4C6-276C9EEEC65D.jpeg217973C1-9EB6-402A-91B3-CCF1B8F7F8AC.jpegAB301308-2A93-4F4C-9F71-60A68A17792C.jpeg
Very cool. The "6" Dart was vastly superior in every way I'm told, but still had no gun. PaulE
Got the natural metal parts done today , using the excellent vallejo metal colors , steel for the exhaust area and white aluminium for the intakes . Ive also got tthe nose cone and anti glare panel on the nose painted black too . 4148BEA9-E05A-4A13-835E-CFB956C6093B.jpeg8A0B280E-B2C3-4E90-993C-D324D27E40DC.jpeg
Started the decalling tonight , after about two hours heres where im at . There are a lot of stencils and warning markings , ive tried to do it as methodically as possible by starting at the front and working my way back , ringing the decal numbers as i apply them . Im only about half way through and theres lots more left on the sheet ! C0424686-F726-4A35-8FD3-7B183F2F000C.jpeg
Well another two hours and another s**tload of tiny and not do tiny decals now on .I was a bit cautious about handling the huge one piece tail decals but I neednt have worried as they went on with no trouble at all- modern Revell decals are always excellent . 1ECB467B-17C9-439F-A10E-820483555A5D.jpeg
REALLY nice model an i wish one of you guys would do a B58 HUSTLER in 1/48 i love that plane as it was a very unusual plane
chris
