Mig 21 PF - 1.48 (Eduard Profilpack)
  • Steve Brodie
    • Sep 2014
    • 4652
    #46
    Originally posted by \
    1st stage of the cockpit is done. Not much to it.............. The PE for the instruments behaved itself, so I'm quite happy with the result............... The side instrument/control panels are the next assembly and fit into the fuselage sides rather than the cockpit floor. ........ If I could take a decent photo I'd be even happier.
    Is that it, all that moaning for 3 bits of plastic and a bit of black paint. Seriously its looking good chap, crack on - watching this one
    • Steve Brodie
      • Sep 2014
      • 4652
      #47
      ...... And i posted my post and then the other photos popped up ops: , looking very good
      • takeslousyphotos
        • Apr 2013
        • 3900
        #48
        You are forgiven.
        • takeslousyphotos
          • Apr 2013
          • 3900
          #49
          Great looking work Peter. Good idea using a tube over the nose cone.
          Thanks Joe ....... It's the only way I could see to do it.
            I like the stenciling on the green nose cone. A nice but subtle contrast between the red and dark green. Nice work there. I would like to see how the fuselage goes together and how much of the pit can be seen in the end.
            Just an odd thought - can you pack the actual hollow of the nose cone with the weight powder stuff and leave it? technically, you will need less weight if you go more forward, which is what the nose cone is-the most forward part of the aircraft
            • takeslousyphotos
              • Apr 2013
              • 3900
              #51
              ooh, good idea on the cone - wait, I use a brush! Still, better to paint the cone and put the decal on before fitting... You can put the weight in the cone too by the looks of it.
              That cockpit is looking excellent and after spending what seems like the last 6 weekends doing anything but models, it's football season kick-off and I am going to embed myself in the man-cave - my wife is going to need a large pry bar to get me out of it Grrr - well so long as she doesn't see this
              I use a brush as well Neil, but there will be a sprayed primer coat, and sealing coat out of a can.......... Thanks for the comments.
              • takeslousyphotos
                • Apr 2013
                • 3900
                #52
                Pulled up my chair a bit late, but I like your work
                Adrian
                ....... Better to arrive late than never at all Adrian............ Good to have you along,, and thanks for yopur kind comment.
                • takeslousyphotos
                  • Apr 2013
                  • 3900
                  #53
                  I fear there isn't going to be much on show one it's buttoned up, unless you peer in closely ........ As for the weight I thought maybe just shoving some Miliput in there would be heavy enough?
                    yeah-you're probably right- but I always like to be on the safe side and chuck in as much as I can without breaking the undercarriage!
                    • Steve Brodie
                      • Sep 2014
                      • 4652
                      #55
                      You are forgiven.
                      Thank wou
                        Hope I haven't missed the band wagon Peter, only just seen this, through Neil's link on his cricket comments post. That cockpit looks fantastic and so does the rest so far. I take it that it isn't an ejector seat? Kami kazie pilots don't need them anyway.
                        Anyway, I'm on board with this now. Keep up the good work.
                        • takeslousyphotos
                          • Apr 2013
                          • 3900
                          #57
                          No worries Geoff.......... There's still plenty of time on this mate.............. Thanks for your comments.
                          • takeslousyphotos
                            • Apr 2013
                            • 3900
                            #58
                            I have the fuselage buttoned up and the top fairing and tail on..........
                            [ATTACH]116583.IPB[/ATTACH]
                            [ATTACH]116584.IPB[/ATTACH]
                            [ATTACH]116585.IPB[/ATTACH]
                            [ATTACH]116586.IPB[/ATTACH]
                            [ATTACH]116587.IPB[/ATTACH]
                            [ATTACH]116588.IPB[/ATTACH]
                            [ATTACH]116589.IPB[/ATTACH]
                            [ATTACH]116590.IPB[/ATTACH]
                            • takeslousyphotos
                              • Apr 2013
                              • 3900
                              #59
                              .......and now I have a question???? I hope someone can answer. On the underside inboard wings there are two lights.The kit supplies two masks which are on and I need to paint from behind before I apply the paint for the undercarriage wells. So, the question these two lights. Would the be floods of some kind or underside navigation lights ???? .......... My gut feellng is that they are flood lights to aid underside inspection / arming ......... But I really don't know.
                              [ATTACH]116591.IPB[/ATTACH]
                              • rickoshea52
                                • Dec 2011
                                • 4079
                                • Rick
                                #60
                                They are probably landing lights that extend out and face forward when the gear is down. On some Boeing 737's this type of light is fitted to the flap fairings.
                                [ATTACH]116594.IPB[/ATTACH]
                                [ATTACH]116595.IPB[/ATTACH]
