Airfix 1/72 Ju 88
  • stona
    • Jul 2008
    • 9889
    #31
    Cheers fellas.
    For the framing I just cut some thin strips of Tamiya tape, stuck it on some tin foil and painted it RLM 70 and RLM 65. Once dry I could liberate lengths, clean up the edges, and apply them to the canopy. I did look at the framing on the full size version and decided not to replicate it exactly. Discretion got the better part of valour! If you make the strips too thin they won't stick which means the framing is inevitably slightly over scale, but the strips give a reasonable impression and are a lot easier than the alternatives.
    The trickiest bit is cleaning up the edges of the strips when you lift them from the foil. I had to put them back on a cutting mat and run a very sharp blade along the edges to remove excess paint and tidy them up. You're going to need a new scalpel blade to cut the strips anyway.
    Next up, when I get home, will be a 1/32 Bf 110.
      Wow Steve, you surely made a "difficult" model into a very nice looking one :-)
      Theuns
        Im sure you will come out on Top with the build Steve, Looking good so far...
        John.
          Well done bud, lovely work here it looks fantastic. Nice one
            Great work Steve!
            Err....and sorry again
            • flyjoe180
              • Jan 2012
              • 12956
              • Joe
              • Earth
              #36
              Very nicely finished Steve. The glazing looks good, the tape strips worked well.
              • dave
                • Nov 2012
                • 1844
                • Brussels
                #37
                Good job on an ill-fitting old kit.
                • monica
                  • Oct 2013
                  • 15169
                  #38
                  great work Steve,so sorry I did miss the build,
                  turned out looking superb
