Airfix 1/72 Ju 88
  • stona
    • Jul 2008
    • 9889
    Airfix 1/72 Ju 88
    I've had no time for modelling for months, but I have a couple of weeks in which I shall attempt this, strictly OOB.
    The kit is the absolutely appalling 1960s vintage Ju 88 from Airfix. It has a lot of raised detail, most of which I've sanded off and nothing fits very well. Apart from that it's great. I've done some basic construction and am now wondering what to do with the transparencies which appear to have been made for a different kit and have no sign of framing whatsoever...you've got to love a challenge
    [ATTACH]117849.IPB[/ATTACH]
    I will be using the kit decals for A6+HH. Contrary to the instructions this was NOT Werner Baumbach's aircraft but a Ju 88 D-1 W.Nr. 1067 belonging to 1.(F)/120, a reconnaissance unit, and regular mount of Staffelkapitan Hptm. Helmuth Orlowski and Beobachter Oblt. Fritz Heidenreich. This aircraft was destroyed in air attack on the ground at Forus Airfield in 1942.
  • eddiesolo
    • Jul 2013
    • 11193
    If anyone can pull it off it is you Steve...hopefully
    I had this kit and struggled so much it was one reason why I got a hatred of making aircraft.
    • yak face
      • Jun 2009
      • 14237
      • Tony
      Nice one steve , im awarding you a bravery gong already for tackling this dog!! I know youll make a decent job of it though , cheers tony
      • tr1ckey66
        • Mar 2009
        • 3592
        Good luck Steve I'm sure you'll conquer this challenge.
        I have the new 1/72 Do17z in the stash probably a much better kit but I'm unsure as to whether I will ever build it.
        This may spur me on
        Paul
          • 22954
          Nice start Steve, also nice to see you building again, and I'm sure you will well and truly beat this one into submission
            Errr...Steve...don't say me, that is one of the kits that I send to you
            SORRY!!! I don't know was a problematic kit
              Don't what your problem is with it, Steve. It seemed fine when I built it. In about 1967. When I was 11. They even made it in a nice light blue plastic so I didn't have to paint the underneath. I probably didn't paint the top either.
              Seriously, I'm impressed - I bet you'll do a great job.
                Good luck
                What else is there to say!
                • PhilJ
                  • May 2015
                  • 1145
                  Yep, can't beat a good challenging kit, saying that I'm gonna make sure my next ones been reviewed as a "easy kit to put together"
                  Phil
                  • stona
                    • Jul 2008
                    • 9889
                    It is Polux. I didn't say so in my post because I was trying to protect the GUILTY
                      Thanks for trying to cover my guilty!
                        Good luck with this - was recently given the Revell Ju 88A-4 from the same era... a bit spartan on detail at the very least! Really looking forward to seeing what you can do with this as some inspiration for me.
                        • colin m
                          • 9024
                          • Colin
                          • Stafford, UK
                          That explains a lot. I was really quite confused by your choice !
                            I actually bought one of these a couple of years ago with the good intentions of bringing it up to date. When I looked at the bits in the box I realised just what a task I had ahead and pretty much put it to the back of the shelf!! I can appreciate what you are doing here Steve and I think you are doing an amazing job already.
                            Maybe one day I'll pluck up the courage to have another go.......................maybe!
                            • rickoshea52
                              • Dec 2011
                              • 4080
                              • Rick
                              I bought one of these in the doubles set from a charity for my daughter, looks like she'll have her work cut out......she's only seven!
