I thought I would make a start before my trip to Croatia as I have a bit of time to spare.
This is my second Dragon model the first being the 1/32 bf110. I loved the bf110 build, nice crisp plastic and a good fit but it had appalling instructions. I remember downloading Eduard 1/48 scale 110 instructions to help and they were more use than the kit ones. I don’t think the 109 instructions are that bad but they are not great. I am really looking forward to this.
The box:
[ATTACH]297859[/ATTACH]
I am not keen on the box top illustration, it looks a bit toy like but what’s inside the box is superb at least as good as the 110 plastic, in fact slightly better if anything as the exhausts are hollowed at the tips. Interestingly sprue J is actually sprue J from the 110 and is labelled as such. It is the 110 engine for use in the 109. I will be depicting this aircraft buttoned up.
All I have done so far is label up the sprues for easy identification and worked through the colours needed. The instructions just give paint numbers for several ranges including GSI Aequos. In these situations I write down the paint numbers listing the colours next to it. The instructions do give a list of colours against the names but it seems a little ‘short’ and on checking I found a lot more colours used in the instructions.
In the picture those listed in the instructions are at the top, at the bottom are the numbers I picked out from the body of the instructions....
[ATTACH]297860[/ATTACH]
I used Google to identify and write down the paint colours next to each number. This will make identification a lot easier during the build without paging through the instruction.
I will be using paint masks for all major markings and I am ready to start cutting plastic. I might get a chance to do a little more and post again before I leave for the airport Monday. If not I will update when I am back in a little over a week.
The box:
