Cyber Hobby (Dragon) Bf109E Trop
  • Steve Jones
    • 6615
    #31
    Barry
    Liking your work! Its certainly coming together well
    • BarryW
      • Jul 2011
      • 6105
      #32
      I have finished priming and on checking joins found very little corrective work to do thanks to plenty of preparation.
      Yellow being known for poor coverage I then sprayed the nose and tail with the MRP sand primer, just a light coat to tone down the contrast before spraying RLM04 Gelb. I got the fairly subtle modulated effect I want.
      Tomorrow I will spray RLM78 underside.
      [ATTACH]304221[/ATTACH][ATTACH]304222[/ATTACH][ATTACH]304223[/ATTACH][ATTACH]304224[/ATTACH][ATTACH]304225[/ATTACH][ATTACH]304226[/ATTACH]
      • scottie3158
        • 14585
        • Holbeach
        #33
        Hi Barry,
        lovely work so far, the dashboard looks very good the dials look perfect
        • BarryW
          • Jul 2011
          • 6105
          #34
          A bit more progress painting the RLM78 underside and lower sides. The lack basing has left me with the modulate colour effect I was after. Very pleased with the result.
          I will be masking up for the top-side and also masking the wheel wells to paint them RLM02 next.
          [ATTACH]304343[/ATTACH][ATTACH]304344[/ATTACH]
            • 16198
            Hi Barry
            Great progress. Really admire your organised, neat approach. Quality results show it is all worth while. Impressed with anyone who can spray yellow so well :thumb2:
            • BarryW
              • Jul 2011
              • 6105
              #36
              A little more done.
              The wheel wells painted RLM02.
              I am hoping to spray the topside RLM79 tonight and may get a little more done tomorrow morning. But then I am flying off to Cyprus for a week and won’t get back to the bench for a bit. I am hoping to have the time to make another post before I go.
              [ATTACH]304388[/ATTACH]
              • BarryW
                • Jul 2011
                • 6105
                #37
                My final post before I am off to Cyprus today.
                RLM79 and RLM80 done.
                I will do the white band when I am back. The pictures I have seen suggest it was applied over the camo so I am doing the same.
                [ATTACH]304448[/ATTACH]
                • flyjoe180
                  • Jan 2012
                  • 12958
                  • Joe
                  • Earth
                  #38
                  Looking great Barry
                  • BarryW
                    • Jul 2011
                    • 6105
                    #39
                    Back from Pafos today and unlikely to get some bench time before Monday night. I did manage to grab a few minutes while waiting to leave for the airport to mask up the white band.
                    I used Tammy tape cut for ‘spacers’ to set where my base line would be measured against a panel line.
                    [ATTACH]305215[/ATTACH]
                    With one good base line it makes positioning the other side easy. Then some tape to widen the mask. I may widen it more before spraying.
                    [ATTACH]305216[/ATTACH]
                    Only when the mask is removed will I be able to tell if it worked. Next post.
                      • 16198
                      Hi Barry
                      Hope you had a great holiday. We love Cyprus - we stay in the Troodos Mountains.
                      Fingers crossed for the masking - always a nervous time unmasking.
                      • BarryW
                        • Jul 2011
                        • 6105
                        #41
                        Hi Jim - we had a great time thanks.....arrived back, nice relaxed and chilled, but now back in the office and feel I need a holiday...
                        I have been making some more progress.
                        [ATTACH]305539[/ATTACH]
                        As you can see above the white band looks pretty good...
                        Masked and sprayed the markings
                        [ATTACH]305540[/ATTACH]
                        Unveiled
                        [ATTACH]305541[/ATTACH]
                        [ATTACH]305542[/ATTACH]
                        [ATTACH]305543[/ATTACH]
                        You cannot beat sprayed on markings....
                        there is a little touching up to do which I will get done over a couple of days then there are some decals to apply.
                          • 16198
                          Hi Barry
                          White stripe looks good as do the markings. The extra work involved in painting markings rather than using decals is certainly worth while.
                          • BarryW
                            • Jul 2011
                            • 6105
                            #43
                            I have been applying some decals and will next be doing some detail painting.
                            [ATTACH]305601[/ATTACH]
                            The decals are a bit thick, hence my using the masks for the main markings, but hopefully I will find tonight that they have settled down under the heavy treatment of decal solution I applied last night.
                            I should be able to get on with some detail painting tonight prior to a sealing gloss varnish coat ready for pin washes.
                            • BarryW
                              • Jul 2011
                              • 6105
                              #44
                              Detail painting done, sealing gloss coat applied, AKI panel line washes applied, first matt coat, then I did some pigment work and streak effects and then after a final matt coat, chipping with Usci metal powders and silver pencil and kerosene and oil leaks. Final fitting and done.
                              I will do a completed thread but just a couple of progress shots here.
                              [ATTACH]305760[/ATTACH][ATTACH]305761[/ATTACH][ATTACH]305762[/ATTACH]
