Bowcat's 1/48 Revell F-15E Strike Eagle
  • rickoshea52
    • Dec 2011
    • 4081
    • Rick
    #46
    I used the plasticard as a shim trick on my Phantom, a tip I got from this site....just goes to show the benefit of this forum.
    Good work.
    • Mr Bowcat
      SMF Supporter
      • Dec 2016
      • 4719
      • Bob
      • London
      #47
      Getting there.
      [ATTACH]302056[/ATTACH][ATTACH]302057[/ATTACH]
      Si vis pacem, para bellum.
      • Mr Bowcat
        SMF Supporter
        • Dec 2016
        • 4719
        • Bob
        • London
        #48
        So, the repair seems to have worked, just waiting for a small section of filler to dry on the leading edge. Once sanded to shape I should finally be able to get the nose attached.
        While I was waiting I got the jet nozzles and ordnance glued up.
        [ATTACH]302358[/ATTACH][ATTACH]302359[/ATTACH][ATTACH]302360[/ATTACH][ATTACH]302361[/ATTACH][ATTACH]302362[/ATTACH]
        • Si Benson
          • 3572
          #49
          Hi Bob,
          Impressed with how your tackling this. Textbook mogelling sir
          Si
          • Mr Bowcat
            SMF Supporter
            • Dec 2016
            • 4719
            • Bob
            • London
            #50
            Cheers Si.
            • yak face
              • Jun 2009
              • 14309
              • Tony
              #51
              Great work bob , loving those exhausts -theyre going to look excellent painted up, cheers tony
              • Mr Bowcat
                SMF Supporter
                • Dec 2016
                • 4719
                • Bob
                • London
                #52
                Cheers Tony.
                  • 22983
                  #53
                  Just caught up Bob. Great fix on the wing.
                  • Mr Bowcat
                    SMF Supporter
                    • Dec 2016
                    • 4719
                    • Bob
                    • London
                    #54
                    Cheers Ian, I was quite please with how it came out. First time I've had to do something like that.
                    I've since come across some other fitment issues, starting to think I won't be building a Revell kit again.
                    • Steve Jones
                      • 6615
                      #55
                      Bob
                      Terrific save! You have every right to be pleased. Patience is the key to this hobby. Judging by the other issues your patience may be tested to the limit Good luck sir!
                      • Mr Bowcat
                        SMF Supporter
                        • Dec 2016
                        • 4719
                        • Bob
                        • London
                        #56
                        Cheers Steve.
                        • Mr Bowcat
                          SMF Supporter
                          • Dec 2016
                          • 4719
                          • Bob
                          • London
                          #57
                          I decided to get the conformal tanks installed before adding the nose, and I'm glad I did.
                          Some parts fitted well, but at the rear there were some pretty significant gaps which required some serious clamping before glue was applied.
                          [ATTACH]302778[/ATTACH][ATTACH]302779[/ATTACH][ATTACH]302780[/ATTACH]
                          Edited to add:
                          To give you an idea of the size of that clamp, here's a picture of it next to the standard modellers reference.
                          [ATTACH]302781[/ATTACH]
                            The not-so-conformal fuel tanks. Great clamp. I need that.
                            • Mr Bowcat
                              SMF Supporter
                              • Dec 2016
                              • 4719
                              • Bob
                              • London
                              #59
                              I usualy use it for woodworking to clamp 2 bits of wood for gluing. I was worried that it would damage the plastic, but when I took it off this morning all was fine.
                                • 16309
                                Hi Bob
                                Fighting you all the way :rolling: Looks as if you have it all under control though. Very neat, competent job on the wing fit :thumb2:
