Build a flying model aeroplane ( HARKER NOODLE ) from a pool noodle FUN BUILD PROJECT
  • wonwinglo
    • Apr 2004
    • 5410
    At the moment it does not look like much but just wait and see what I make from a pool noodle,if you want to build one yourself then tag along and follow the instructions.
    First cut one 18 inch length of pool noodle,take some 1/32nd balsa sheet and glue it around the noodle.
    You can use ordinary PVA dhesive to glue the balsa to the noodle,bind tightly with masking tape like this.
    Sand the covered noodle well.
    Next cut the ends off level and sand flush,cut two discs one of ply for the engine mount and one balsa sheet for the tail portion,more later on that when we come to it.
    Use plenty of adhesive for the engine mount,clean off surplus.
    You will now have something looking like this,sand the ends smooth,this will be the fuselage but wait and see what we do to it !
    • 22983
    Looks very interesting, I'll tag along with this Barry.
    • wonwinglo
      • Apr 2004
      • 5410
      Now the round fuselage has been constructed we can turn our attention to the tail surfaces,this is how it was done.
      Balsa sheet serves well for the tail surfaces,to simplify things the rudder is the same shape as the elevators.
      A slot is cut out to receive the tailplane which is firmly glued into place,pins are inserted to hold things level while the adhesive sets.
      Next the fin is added with some side gussets to hold things level,note the centre line marked in pencil on the fuselage.
      Next the wing pylon parts are cut out and assembled,everything on this model is functional and designed for simplicity.
      • wonwinglo
        • Apr 2004
        • 5410
        Elevator installed but not yet hinged.
        • Gern
          • 9307
          I gotta question Barry. What in the world is a pool noodle??
          • adt70hk
            • Sep 2019
            • 10552
            Following this with interest. My local hobby store specialises in RC aircraft and even has a couple of jet ones hanging from the ceiling.
            ATB
            • adt70hk
              • Sep 2019
              • 10552
              They're floats for use in swimming pools. Link here
                • 22983
                these Dave
                • Gern
                  • 9307
                  I don't get out much. Thanks guys.
                  • wonwinglo
                    • Apr 2004
                    • 5410
                    ATB
                    You are so lucky to have a model shop in your area,they have all closed around here,we used to have about 8 all gone forever.
                    • Neil Merryweather
                      • Dec 2018
                      • 5352
                      • London
                      Incredible !
                      is it going to be a HORSA?
                      • wonwinglo
                        • Apr 2004
                        • 5410
                        Incredible !
                        Now there is an idea Neil,that could be done from a pool noodle ! that may be built in the future thanks for the idea.
                        • scottie3158
                          • 14635
                          • Holbeach
                          Dave,
                          I didn't know either.
                          • wonwinglo
                            • Apr 2004
                            • 5410
                            The lower wing cradle is added plus the simple lower wing is mounted.
                            • wonwinglo
                              • Apr 2004
                              • 5410
                              Todays progress on the Harker Noodle.
                              Barbecue sticks for wing struts and depron underfloor heating sheet for wings with spruce strips on leading edge.
                              The pilot has the luxury of a scooped out pool noodle cockpit with built in padding.
                              Just wait and see this simple aeroplane fly !
