Airfix 1:72 HS Buccaneer S2B
  • colin m
    • 9066
    • Colin
    • Stafford, UK
    It seems the Buccaneer was quite a popular aircraft, its low level ride was fairly smooth (unlike its successor the Tornado) indeed there was a belief that the only replacement for a Buccaneer, was, another Buccaneer !
    XX895 was delivered to the RAF on the 12 May 1975 and in early January 1976 issued to 12 Sqn, RAF Honnington.
    January 1991 saw XX895 prepared for deployment to the Gulf on operation Granby, which included being painted desert ARTF (Alkali Removable Temporary Finish) and the code ‘G’ applied.
    17th March 1991 saw XX895 return to RAF Lossiemouth. This model will be built with this transit payload simply because I like the asymmetric look !
    During ‘Granby’ XX895 was to take part in 10 missions, 3 were DNCO (Duty not carried out) one was down to weather, another was no in flight refuelling available and the final DNCO down to a U/S Tornado ! The Buccaneer was to prove so reliable that the two reserves left behind in the UK were never needed.
    So, the build. Well I haven’t done much building recently as I’ve been busy decorating the house, but once in a while when there’s a lull in decorating I’ve done a bit on the Bucc’.
    The Airfix 1:72 Buccaneer is an old mould lacking in detail. Hence the build started with the purchase of a cockpit PE set and scribing in some surface detail. The scribing was a bit of a nightmare. It was one step forward two back. But, just doing it bit by bit seemed the way forward. Anyway, on with the build.
    I started with the scribing of various panel lines and access panels, lots of artistic license was used here. With so little detail, it was just crying out for some attention.
    The intakes will need a lot of work.
    As will the seams, well it is a very old mould !
    The one and only Sidewinder is getting new fins, the kit ones were just too thick
    The bang seat. The kit item has gained 11 pieces of PE each. What a pain !
    The cockpit was quite straight forward, except I dropped the IP into the fuselage, but luckily, recovered it through the exhaust port !
    And that's it for now. Time for a bit of preshading.
    [ATTACH]44089.IPB[/ATTACH]
    [ATTACH]44090.IPB[/ATTACH]
    [ATTACH]44091.IPB[/ATTACH]
    [ATTACH]44092.IPB[/ATTACH]
    [ATTACH]44093.IPB[/ATTACH]
    [ATTACH]44094.IPB[/ATTACH]
    [ATTACH]44095.IPB[/ATTACH]
    • 22983
    A very good start on this Colin. Got this in the stash so will watch with interest
      Looking good, the bang seats look fantastic, but can imagine the PE was a bit on the fiddly side to do!
        The Buck was a lovely looking aircraft, we often had them in the visiting aircraft support section
        Watching with interest as I haven't done one of these since I were a lad
          • 18302
          That bang seat is a work of art! Nice.
          The cock pit looks great as well.
            That's coming along very well Colin, even with all the necessary alterations!
            The Buccaneer is definitely a favourite of mine, even in the Gulf war they were still performing a vital low-level attack role, something the Americans couldn't handle. Mind you, their idea of low is over 500ft!
            Patrick
            • yak face
              • Jun 2009
              • 14309
              • Tony
              Nice one colin! We all love a nice buccaneer. The ejector seat looks superb , as do the instrument panels , great work. It looks like the seams might be a bit tricky but im sure youll beat it. Keep the pics coming , cheers tony
                doing a great job on this m8 keep going
                mobear
                  so far really great...
                  keep it up
                  Roman
                  • colin m
                    • 9066
                    • Colin
                    • Stafford, UK
                    A little bit more done. Pre-shading, I nearly always have a go at it, if I loose it under the top coat, well never mind.
                    [ATTACH]40503.vB[/ATTACH][ATTACH]40504.vB[/ATTACH]
                    The primer showed up a few areas that needed even more attention, but hopefully it's all covered now. Now for the first top coat. I'm going back to enamels for this one as I want it to match the other two Gulf war planes I built a while ago. I think there's just enough paint left for this one - we'll see.
                    [ATTACH]44191.IPB[/ATTACH]
                    [ATTACH]44192.IPB[/ATTACH]
                    • yak face
                      • Jun 2009
                      • 14309
                      • Tony
                      Certainly looks like a bucc to me colin! Are you doing it wheels up in flight or have you just temporarily fixed the u/c doors for painting? cheers tony
                        Looking good so far Colin!
                        Patrick
                          • 22983
                          Looking very good Colin keep up the good work
                          • colin m
                            • 9066
                            • Colin
                            • Stafford, UK
                            Thanks all for having a look,
                            Tony, does this answer your question ?
                            [ATTACH]40519.vB[/ATTACH]
                            [ATTACH]44207.IPB[/ATTACH]
                              Following with interest, I have the SAAF version of that Buck inmind.
                              Theuns
